No beep, no display, tested power supply and comp. monitor, tested RAM and graphics- no probs.. new proccesor and motherboard still nothing...
    Problem Solver:
  • 4 Answers
Causes for no display are :
1. SMPS : Most likely, replace
2. RAM : Most likely, replace
3. Motherboard : likely if it is old
4. Processor : unlikely if it is Intel
5. Graphics Card : Try on board graphics
Thanks
Bhaskar
Posted on Jun 04, 2008
Moderately Experience Comp Repair Girl Needs Some Help.
Well this usually happens! Its weird but I have no more theory, with a new Power Supply will not work, believe or not sometimes old computers [or in this case motherboard] will not even boot the BIOS with a different power supply than the one that the motherboard has always used, sounds weird but if you try it, you will see that will boot like if nothing happened before... give it a try and tell me how it goes... Best regards and LUCK!!! Luis
Jan 23, 2012 | Computers & Internet
When I tern on my comp it is 3 beep what a problem
The Problem With RAM, If 3 short beeps( AMI bios). Video Problem Display Problem if One long beep and 2 Short beets( Award bios)
Remove the Power Connector from PC, and Open the cabinet and Locate the RAM, Remove it and put it back to same or diffent socket, or Try with New RAM.
if still no Use then it is the Display Problem, If display adapter is Onboard then motherboard needs Repair(Chip Level). try with new Graphics card. If you have any Graphics Card earliar then Try with New one. best of luck
Feb 03, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
DEAR SIR IAM USING COMPAQ PRESARIO SG3053IL MODEL PC WITH FOXCONN 945GZ7MC MOTHERBOARD.PAST IT IS WORKING FINE. BUT RECENTLY WHEN I SWICHETED IT ON, I OBSERVED NO DISPLAY IN MONITOR. COMING TO MY...
I don't think we should directly blame it to the Power Supply, but I can't make it very thorough since you didn't mention whether the system can boot up or not even without display or not. Can you hear beeps or fans' sound when you press the Power button on the computer? Have you tried the monitor on another computer? or have you tried another monitor on your computer? or have you check the video cable? Have you checked the Ram? Have you checked the power supply unit (smps)? Have you checked the Power cables? and many more. If you haven't done all these, do one by one and replace the necessary components respectively and keep trying, if nothing's worthy, then it must be the video card on the motherboard which I would recommend installing a new video card (add-on graphics card). It's also possible that there's problem with the Motherboard bios.
In most cases, the Ram is the cause, once you replaced or checked Ram, you'll be able to find out what exactly is the root of the problem.
These are the basic steps of troubleshooting a display problem.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
Motherboard power is on but cannot display screen, the monitor is black or no screen.
your problem could be almost any of your hardware components
the best way to detirmine wich one/how to fix it is with a process of illimination. You should do this by switching your hardware components with known good ones.
being a display problem the order i would test with is this.
  1. disconect everything but the screen
  2. swap screen for a known good one
  3. disconect graphics card and try the onboard (if no onboard try another gc)
  4. test psu (power supply unit) this can be done with either a psu tester, multimitre or try with another psu
  5. try removing all your RAM, when you boot if your system beeps a couple of times you know that your motherboardand cpu are good. if it doesnt beep it is probably your motherboard or cpu.
Oct 14, 2009 | ASUS P4P800-MX Motherboard
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Is motherboard dead?
Either motherboard, ram module or if no power at all sounds more like a power supply. If the computer has on board video you will need the ram to get any video. But with it removed the board should still beep if the case speaker is connected to the board. Have seen a lot of these less expensive motherboards fail. If there is no power up at all or lights coming on on the case I would think it is a power supply problem. Happens all the time and quite easy to repair. Just put on a new power supply.
Dec 12, 2007 | EliteGroup ECS P4M800-M Socket...
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
