Question about Ricoh Aficio 1035 Copier
Aficio 400 code SC323
There doesn't seem to be a code in some Ricoh manuals I have found. Whenever it comes up, we need to shut down the machine and turn it back on. It goes away then later it comes back. Do you know what the root of the problem is?
Thanks!
  • 162 Answers
Laser not enough power, due to aging
It must be replaced.
Posted on Nov 15, 2009
  • Ricoh Master
  • 2,794 Answers
Is there any error codes before you turn the power off?
Posted on Jun 09, 2008
  • Tim Babcock
    Tim Babcock Jun 09, 2008
    We checked our Ricoh service manuals here at work and can't find an error code that starts with SC. Please verify.
  • 417 Answers
Hi there this is from the service manual. Suggest the Laser cooling fan blocked. if not faulty LD Unit.
Thanks Jason.
SC323: LD drive current over
-Definition- [B]
The LD drive board applies more than 100 mA to the LD.
- Possible causes -
· LD unit defective (not enough power, due to aging)
· Poor connection of the interface harness which connects the LD unit and
the EX-IPU board
· Temperature around the LD unit is too high
Posted on Aug 17, 2008
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Aficio 2015 ADF not working
if you plug the ADF connector while the machine is on the code will appear when you connect the ADF shut down the machine and then connect the ADF plug
Jun 22, 2009 | Ricoh Aficio 2015 Copier
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
May 18, 2009 | Ricoh Aficio 1035 Copier
SC 400
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Jan 11, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 1035 Copier Logo
545 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
