Question about Sharp UX B700 Plain Paper Inkjet Fax
Can't copy Changed cartridge, keep getting printer error check paper. I've put in new ones 10 times or more. What's wrong?
  • 487 Answers
Paper might be stuc in the machine at the roll.
Open remove piece of paper. Unplug maciine and try again
Posted on Jun 08, 2008
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Epson Stylus CX4600 All-In-One
Try removeing all the cartridges, start the printer do you get a error message code?
put them back and check the error and code again.
Thanks, waiting for your reply.
Jun 01, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error messages but I can't find the errors
ona brand new machine you get a starter cartridge, you will need to put in a new cartridge
Feb 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper comes out with nothing on it
On the new cartridge, did you remember to remove the plastic seal from the toner? Do you get blank sheets only when you print or when you make copies too? Were you careful when clearing the paper jam or could you have accidentally damaged the printer?
Jan 07, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Sharp UX B700 Plain Paper Inkjet Fax Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
