Question about HP Deskjet 2360 InkJet Printer
Paper feed problem
I have HP Deskjet 2360 printer. When I give print command than it accepts paper but paper gets stuck in halfway. After that it gives a message of paper jam. After switching off printer throws that paper without any printing and repeats same paper feed problem. I purchased another 2360 but it also gives same problem. Pl help
Thanks
  • Bhaskar Yadav
    Bhaskar Yadav Jun 04, 2008
    Thanks
    Master:
  • 638 Answers
Usb port or printer adapter problem.check both of them.wish success
Posted on Jun 04, 2008
How to reset hp deskjet 2360
HOW DO YOU RESET HP DESK JET 2360.iT KEEPS SAYING PAPER JAM,BUT THERE IS NO PAPER IN IT.
Jan 25, 2010 | HP Deskjet 2360 InkJet Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
Can't get instuctions for my paper feed cleaning kit!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks
Thiru
Jun 15, 2009 | HP DeskJet 520 InkJet Printer
Printer light always blinking
either out of paper and something still waiting to print or inks low
hope this helps :)
Jun 10, 2009 | HP Deskjet 2360 InkJet Printer
My HP Deskjet 882C no longer pulls paper from the feed tray
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | HP DeskJet 882c InkJet Printer
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Oct 15, 2008 | HP Deskjet 2360 InkJet Printer
No pRINT
cartridge is faulty or may be the circuit touching the cartridge surface is not clean.try to clean n reinstall cartridge.or if needed reinstall driver after that.wish u success.
Oct 17, 2007 | HP Deskjet 2360 InkJet Printer
HP Deskjet 2360 InkJet Printer Logo
253 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
