Question about Nokia 6126 Cellular Phone
Nokia 6126 Screen problem
When I open my Nokia 6126, the screen stays dark but the keys do light up. The outer screen does work but it is rather dim. The inner screen is totally dark.
  • themapman Jul 19, 2008
    My nokia 6126 has the same problem. The outer screen lights up, as do the keys.but the main screen just shows various flashes of light - no menu, and often no light at all
  • Vervada Aug 09, 2008
    I have the same phone, and I was just at camp for five days. I didn't do anything to it, I came in after dinner or something and opened my phone and the screen is lit but black. I think it may be a wiring problem from over-flipping the screen (lol) but the phone itself still works. I can play music and videos still, as I remember the menu. This problem is extremely aggravating for a text-a-holic... I'll try resetting it and see what happens...
I also have a Nokia 6126, and this happened to mine, too. Did you drop it? I drop mine ALL the time but when mine did it, the keys lit up, the front screen lit up, but the main screen stayed black. I took it in, and my display was broken. I shipped it back to Nokia and it was apparently 'not fixed' because there was too much physical damage and water damage, but when I got it back, it worked. Go figure. It may work itself out; but you may wanna get it checked out to be safe.
Posted on Jul 18, 2008
    Problem Solver:
  • 7 Answers
I have to say, the same thing happened to both of my nokia 6126's.
Posted on Jul 15, 2008
I have a Nokia 6126 that the screen turns white and the phone resets when I try and open the menu.
Your phone's batteries are most probably worn out. Replace with new one. Ensure you purchase authentic ones from a genuine store and not the local ones. Otherwise, chances are that the problem may still persist.
Jul 25, 2010 | Nokia 6126 Cellular Phone
Nokia 6126 screen is blank
the problem with the screen of your phone is that the flex on the screen of your phone is bad.
All you need to do is just to change the flex on your phone screen and your phone screen will start to display.
Take care
Apr 26, 2010 | Nokia 6126 Cellular Phone
Can i find a panel for my nokia 6126?i want to recycle my phone,is it possible?i want to make my phone look new?i want to update my phone`s software?
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 18, 2010 | Nokia 6126 Cellular Phone
Dark dark screen
that rubbery nipple when its pressed in is what allows the screen to go into sleep mode. Sounds like it might be stuck halfway in between. Go ahead and try to take out the top cover with the rubbery nipple on it. See if the screen lights up like normal, if it does then you know the rubbery nipple is the problem and just needs to be readjusted so it doesn't get stuck.
If it still stays dim then its either the lcd or the inverter that is bad.
Jul 04, 2009 | Compaq Presario X1000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Screen problem for Nokia 6126
Are you certain you have a strong GPRS signal? Have you tried turning the phone off for a few moments and then back on, and also make sure you have good signal strength at the time you are trying to send an MMS.
 It could be due to network problems as well - the few times I've experienced it, it has lasted for several days and then it has been fine after that.
Nov 22, 2008 | Nokia 6126 Cellular Phone
Nokia 6126 screen not showing
the problem is in display...better change ur display and use it...
Sep 19, 2008 | Nokia 6126 Cellular Phone
Nokia 6126 DARK screen
hi i think because of too much damage....you can change the screen by replacing 6120 screen
Sep 10, 2008 | Nokia 6126 Cellular Phone
DARK SCREEN
u can get its screen changed from the nokia service centre
May 18, 2008 | Nokia 6126 Cellular Phone
Back light
if you mean that only the backlight is not working then this may have happened when you opened the handset you didnt place all correctly ...
just open it again and near by screen there will be a pin or chip which must touch the board to get backlight ... so i think that might not be touching the board ...
so open it and make it touch the board ...
you will get the backlight...
your problem is minor one you can solve it by your self ...
this has happened due so loose conntact inside ....
Mar 31, 2008 | Nokia 6126 Cellular Phone
Nokia 6126 Cellular Phone Logo
191 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
