Question about Refrigerators
Dirty Ice Dispenser
I am having a problem with black stuff coming out of the ice dispenser ( the shoot where you put the glass). Does anyone know why this is or how I can clean it? Just rented the house, not sure how old the fridge is. The water side is fine. Thanks,.
  • Anonymous Mar 17, 2014
    How to clean
I am having a similar problem. The black stuff is all over the inside--it's probably mold. Anybody out there with good advice?
Posted on Jun 12, 2008
The ice dispenser is not working
If your design is the conventional with a catch bucket and auger it is likely that the output has frozen and is prohibiting the cubes to enter the shoot. Remove the bucket and discard the ice. Inspect the shoot in the door and clear any ice built up. Check that the catch bucket auger is free to turn and no built up ice in the output side that lines up with the shoot.
If the door to the shoot located in the freezer door fails to close completely then frost and ice will continue to build up in the shoot.
Cycle by hand a few times to ensure that the door will close. Also when dispensing ice ensure that the arm that contacts the glass has returned to the front position ensuring that the door is closed.
Wait for a new tray of ice. It will take a minute or two for the ice to find its way to the glass from a completely emptied bucket and shoot.
Hope this has helped?
Jan 17, 2016 | Refrigerators
Firgidare ice dispenser dispensing ice without the switch bring touched. Is this a control board issue or something else?
try taking you ice tray and dispenser out and cleaning them of any frozen ice. sometimes the dispenser system kinda jambs and then stuck ice come out as it melts slightly and frees itself from the dispenser shoot and mechanism good luck
Mar 19, 2015 | Refrigerators
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker dispenser door
you need an ice duct door spring and selenoid call ge at 800-851-6200 about 40 dollars for parts they go in the freezer door despenser area
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Ice dispenser in door clogged up or frozen
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Oct 15, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
410 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
