Question about Sony KDF-E42A10 42 in. LCD Television
6 red blinks
My TV was working fine then when i tried to turn it on it wouldnt turn on
and the standby light blinks red 6 times. i would really like to know what this trouble code means
  • mdjgs Jun 13, 2008
    I was watching a show, then I went on to change channels, all of a sudden my tv went blank. no picture and no sound. But there was this "standby" red light blinking, unplugged the tv, then I plugged it in. I turned on the tv, and the picture was there for 10 seconds, then it went black and again it started blinking.
    I have used my original remote control, my comcast remote control, and of unplugging every item, then plugging it in again. Nothing, still blinks.
  • Anonymous Jul 02, 2008
    I have exactly the same problem - wont power up and light blinks 6 times
    Scholar:
  • 137 Answers
Hello MCMECH,
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: 1-576-912-11 Average cost $8.00 You can purchase it directly from http://www.partstore.com/GetModel.aspx?MfgName=Sony&BrandName=Sony&ModelNumber=KDFE42A10&PartCategoryName=&Keywords=%091-576-912-11+&x=18&y=14
Best regards
Circuitcity
Posted on Jul 17, 2008
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
MY SONY TV MODEL # KF42-WE610 IS SOUND IS COMING ON BUT NO PICTURE
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
Sep 30, 2014 | Sony Televison & Video
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Televison & Video
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
Sep 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDF-E42A10 42 in. LCD Television Logo
523 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
