Question about Motorola Mobility C168 Cellular Phone
Ring tones are all silent
I cannot hear my ringing or any of my ringtones. I have checked all volumes and everything is is set on number 5. Please help!
No sound
  • DALLASS Oct 09, 2008
    ALL OF MY RING TONES ARE ON MUTE FOR MY MOTOROLA C1681. CAN ANYBODY HELP?
Try to turn the phone off and then back on.
Posted on Jun 09, 2008
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
Ringtones silent
Make sure that you didn't turn your phone to silent. Hold down the # key and see if it say silent or loud, soft, etc.. Make sure that the volume is turned to maximum, by using the top switch on the left hand side of your closed hand set. Make should that you have a ring tone assigned because if not nothing will work. Follow the below instructions
Menu-Settings-Ring Styles-Detail-Calls (Assign a tune)-click OK
This should get your ring tone back
Feb 26, 2011 | Motorola Mobility RAZR V3
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My ring tones have stopped working on my Blackbery
There may be a setting that got adjusted somehow. Go into your Options (the wrench icon) and select "Sounds and Ringtones." Under "Ring Tone," there is a volume setting -- make sure it is not set to "Silent." Underneath that, there is a setting called "Play sound" -- make sure that's set to "Always"or "Out of holster."
Do other sounds work on your BlackBerry (such as music files, video clips, or alerts)?
Jun 01, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
I have a Nokia 2610 can't hear ringtone.
Select Menu, Settings, and change any of the ring tones. Select, ALERT FOR to set the phone to ring
Aug 07, 2009 | Nokia 2610 Cellular Phone
Can't get rid of silent mode
Depending on what type and make of phone; you might have volume control on the sides of the phone. If so try to adjust the ring type there.
Another thing to try would be to check the profile setting of your phone. Some Motorola phones have this option in which a paticular ringtone is assigned to the profile. Change the profile setting on your screen and this should solve your issue.
May 29, 2009 | Cell Phones
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Jan 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Motorola Mobility C168 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
