Question about Acoustic Research 900MHz Wireless Stereo Headphones - Black
Acoustic Research AW772 Wireless Headphones
Sometimes when I place the head set in the cradle the green light goes out and sometimes it stays on even with the TV off.
With the head set in the cradle is the green light supposed to be on or off.
Also, where can I get a set of instructions for these wireless headphones?
Thanks so much.
David Eichelberger
  • 2 more comments
  • Anonymous Dec 02, 2008
    I'm having the same problem. When I place the headset in the cradle, sometimes the green light stays on and some times it goes off. When the green light turns off, the red charging indicator light is supposed to light up but it does not.
  • MSWELLER Dec 12, 2008
    On Acoustic Research AW772 Wireless headphones the left earpiece got pulled off and the wires are intact but disconnected. How can I find out where I solder them back in?
  • Anonymous Dec 17, 2008
    Phone does not seem to be charging. The red charge light is always on. The green button on the base station is always on. Shouldn't the red charge light turn green when it is charged?
  • Anonymous Jan 16, 2009
    I have a set of aw772 head phones..Problem.. they started with intermitent scrathing sound & then no sound at all. Now when put in cradle the light goes out,and no chaging indication. Please advise if there is a place I can send for repair,or if not replacement? thank you adietz@ndsupernet.com
3 Suggested Answers
SOURCE: need installation manual for acoustic research headphones
I have lost the manual of my RCAmodelnumverWHP150 how can I find another one?
Posted on Feb 24, 2009
  • 20 Answers
SOURCE: I need ni-cad battery specifications for Acoustic
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Posted on Aug 14, 2011
Where can I order new headphone pads for my Acoustic Research AW772 wireless headphones?
The 90mm leatherette cussions from Scan Sound fit and are comfortable. They are round but stretch to fit.
Nov 29, 2013 | Acoustic Research 900MHz Wireless Stereo...
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
I have 2 sets of Acoustic Research AW722 headphones. Both sets of the ear cushions' leatherette outside material have disintigrated. I cannot find any replacement parts anywhere. The size of the...
I just purchased and installed a pair of 90mm leatherette headphone cushions from Scan Sound (LEC90) it took about 10 min to insall them (they are round but stretchable) They are very comfortable.
May 06, 2011 | Acoustic Research 900MHz Wireless Stereo...
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
I got a pair of this acoustic research head phonebut when i tried to recharche then the red light did not turn onit loock that the all system won't workwhat can I do...
I hope this one is not kept too long idle and without charge. Check on the points and the connections and try again maybe put it on for sometime to enable time for triggering any low voltage stage from where it has to recoup. Hope this will help
Jul 01, 2010 | Acoustic Research AW-721 Consumer...
Will not stay on....
I dont have an answer or suggestion to this. I am having the same problems aswell with these damn headphones. I dont know what to do with em. The longest theyll stay on is about 10 minutes. Then they cut off. But it charges the headphones fine?
May 26, 2010 | Acoustic Research 900MHz Wireless Stereo...
Need head phones only for aw772 wireless
try on ebay.com  or just replace the entire unit as these wireless headphones are always getting better and less expensive.
Apr 01, 2009 | Acoustic Research 900MHz Wireless Stereo...
Need installation manual for acoustic research headphones
Feb 23, 2009 | Acoustic Research Audio Players &...
Operating manual
After connecting all cables.... try channel 1 at the receiver... then move tuner up and down until the green light on the left headphone lights up and you can hear whatever you are listening to. If channel 1 doesnt work, try 2 and 3...... mine is set on CH3.
Good luck
Oct 31, 2007 | Acoustic Research AW-721 Consumer...
Acoustic Research 900MHz Wireless Stereo Headphones - Black Logo
418 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
