Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42xxx Error Protection Codes
Dear Guru,
did some component level tbshoot before enlightened on level 0 LED stuff. I am about 99.99% sure not faulty power supply so these two LEDs on power module will shed some light on possible faulty component? Again, the Red LED on facia is screaming 7 blinks on then a 3 count-7 blinks on then 3 count, etc. ?? Probably have to go out and do second tbshoot....
  • 138 Answers
Unplug the Y main and see if the 7-blink stop and go to a green solid. If so replace the Y main.If not unplug the X main and do the same. Check the voltages on the PSU and make sure they are correct with the voltages as the panle says.
Posted on Aug 19, 2008
Phillips TV doesn't turn on. Short LED activity (400ms) if the cord is unplugged and plugged back into the outlet. The LED lights up for 400ms and goes dark. Read details for more.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 13, 2016 | Televison & Video
Hello.my philips fidelio ds 9/10 does not work.both sound led are blinking but nothing else.what can i do?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 13, 2014 | Philips Televison & Video
Philips 42 PFL7962D do not turn on. The blue light go on and blinking after every 10 second.
Nov 05, 2014 | Televison & Video
The red light goes green then flashes red
This is a error code more than likely a power issue. Check the power supply of the Philips web site for the error codes.
Jun 15, 2014 | Philips 42FD9954 42 in. Plasma HDTV
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Jan 20, 2009 | Televison & Video
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
