Question about HP Officejet 7210 All-In-One InkJet Printer
Cant get black ink cartridge to install correctly
Seems like the small spring like armature has something to do with it
  • Anonymous Jul 05, 2008
    Can't get the cartridge to go in right. misplaced manual
    Scholar:
  • 162 Answers
When installing new ink, tap it on a desk prior to inserting it into the machine. also, check to see that the ink is being impaled. Sometimes the point gets broken off and it will never print.
Posted on Jul 25, 2008
C 3180 hp printer, just bought from thrift store, ----but,,,it seems the thing that holds the ink cartridges is stuck, though its trying to slide as it should, it seems to be hitting,jamming , light re;...
First of all, if the ink cartridges are stuck, as you rightly guessed, it may not be the correct cartridge.
Now, even suppose, it is the correct cartridge, it would not have been installed correctly . the Label side of the cartridge should face upwards, Not towards you.. when you are inserting the ink cartridge.
if you are from India the compatible ink cartridge would be HP 850(BLACK) AND HP 855(COLOR)
In North,South America it is HP 92(BLACK) AND HP 93.
Aug 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I get a "no cartridge" error though I've replaced cartridge. Cartridge works in another identical printer.
Check the two electrical contacts on the ink cartridge for small marks, which should appear if the ink cartridge was installed correctly. If the electrical contacts do not have small marks: 1. Re-install the ink cartridge, making sure you press down on it until it clicks into position. 2. Remove the black ink cartridge, then check the two electrical contacts on the cartridge again for small marks. Repeat if necessary. 3. Re-install the ink cartridge.
Jun 10, 2009 | Kodak Easyshare Printer G600 Thermo...
Can't scan when of Ink! What is the small black cartridge for?
You must have ink installed to scan.
Small cartridge is a print head.
Jan 26, 2009 | Canon PIXMA MP610 InkJet Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Black cartridge is not being recognized, amber light blinking
Nov 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Does not recognise the smaller black ink cartridge
This machine is not meant to switch between the two black cartridges. The large one is used when you are using black only, and the small one is used when you are printing in color.
Jul 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
Ben Johnson
