Question about Cartoni Photography
Cartoni Gamma tripod head
I have a Gamma head, model # G-980708 I believe?, and need to repair the the quick release camera plate retaining lever. When I insert the camera plate into the tripod head the lever clicks to retain the plate but it will not allow me to push the lever to further lock in the plate. The lever will go all the way to where it should end up but the needed tension is not applied, so it is not locking in the plate. Is this a spring that needs to be replaced or a tension screw ? I would like to do the repair myself, what do you recommend? Thank you for your help. Kyle note: this is the lever at the back of the head that allows you to remove the plate after you push in the safety release button. When I push it all the way right it does not lock in plate. It remains loose.
Agent Allan
  • 480 Answers
SOURCE: Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Posted on Apr 16, 2008
  • 24 Answers
SOURCE: Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Posted on Feb 10, 2009
SOURCE: quick release plate for vidpro tripod 2000
Go to Wolf Camera. They have them in stock
Posted on May 31, 2009
SOURCE: quick release plate for quantaray tripod
www.tripodquickrelease.com They have just about everything you need
James Sprenger
Posted on Aug 31, 2009
SOURCE: Quick release plate for a Heiwa HS-744 tripod
Have you had any luck? I need one for the HS-644B model.
Posted on Mar 03, 2010
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
I need a guide pin for a cartoni b511 quick release plate and i can not find one
If you are looking for a non-threaded 'locating' pin to stop smaller video cameras from twisting on the plate...Cartoni does not make one!!! You will either need to mickey mouse something or purchase a new camera plate from another manufacturer that offers this. Luckily this plate is a standard 'Euro' plate used by many video tripod manufacturers. For example, I know the Miller cat# 860 will take a cat# 493 DV carriage which provides not only the 1/4-20" screw but also the locater pin as an assembly.
peter
Jul 02, 2012 | Cartoni B511 Quick Release Plate
I cannot figure out how to get the plate off the head. I end up either putting camera on, then twisting the whole thing onto the tripod, or putting the head on the tripod and twisting the camera around to...
Sounds as if you haven't unlocked the quick disconnect plate from the 222 head.
Release the quick disconnect plate from the 222 pistol grip with the thumb release it will click open and pop the release plate up a bit to remove it. The affix this plate to the camera tripod socket 1/4 x20 female thread on the camera bottom. The underside of the quick release plate has a "D" ring to screw it to the camera, fold over the "D" ring and when you pit it back on the 222 set the edge under the lip and set it down the brass pin then will snap the thumb release over and lock into place.
See my diagrams
And the release plate
Jan 22, 2011 | Manfrotto 222 GripAction Ball Joystick...
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Once the camera is attached to the tripod, how do I remove the plate with camera still on it?
There should be a release button or lever at the back or bottom of the top plate to release the quick release
Feb 05, 2010 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Dear spiderinkart,
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
3030G pan tilt head
The little brass arm is supposed to be a safety switch. In one position the release lever bumps into the brass are and will not turn so the quick release willnot come off. In the other position the brass arm is away from the lever so it swings freely and the quick release plate will come off. With the brass arm open the quick release lever shoulde lock open until you push the quick releae in place. If none of this seem to work on your head, you may be missing parts. Try www.bogentripodparts.com
Feb 19, 2008 | Bogen Communication Bogen Manfrotto 3030G...
Photography Logo
555 people viewed this question
Top Cartoni Photography Experts
pontelemon
pontelemon
Are you a Cartoni Photography Expert? Answer questions, earn points and help others
