Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave
My 3 year Ge spacemaker microwave is cutting off during cooking time. I reset the time and date and try to cook for any amount of time and it cuts off after 2 seconds. Is this something that can be repaired?
  • 4 more comments
  • Anonymous Jun 06, 2008
    same problem...regardless of power setting...light seems to flicker then dispalys all kinds of crazy characters on display until reset
  • Anonymous Jun 11, 2008
    I had the same problem with the power cutting out. I reset the clock and 2 seconds into cooking it cuts out again!
  • Anonymous Jun 16, 2008
    Same problem. Mine was manufactured aug, 2004. Looking for a soultion. You have to have microwave these days.
  • jsurace Jul 25, 2008
    our GE microwave dies competely after about 2 min and will reset after a few minutes. is there a breaker somewhere.
  • chickie2465 Jul 26, 2008
    I have been having the same problem with my microwave. Oddly enough, I put a glass bowl with about 1/2 cup of water inside the microwave on the wire rack, and this prevents it fromm shutting off after two seconds. But when the water has evaporated, it starts doing it again. Go figure.I'm still hoping to find a permanent solution, but until then, I will keep using my bowl.
  • Tazina Jul 31, 2008
    My microwave is having the same problem. What parts are needed and where do I purchase the parts?
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in a bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit.
The parts kit is similar to this one: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
Profile series kicks out during operation
My GE Profile series Spacemaker Microwave, model JVM2070BH002 after we set the cooking time will kick out after about 3-5 seconds. This is sporatic. It will work for a week and the kick out for 3-4 times.
on Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven Problem:
if a microwave cuts off when cooking, then there is a problem. i have never heard of a " FEATURE" like that.
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave cuts off after heating for about 3-4 minutes
There is a overtemperature device inside that is shuting you down until things cool off. Take the cover off and clean up everything as much as possible. Grease from the cooking can get all over everything inside and collect dust buildup enough to obstruct the airflow and cause overheting.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave power interruption
the unit may be detecting a mal-functioning magnetron.
Jun 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
