Viking HS5008 Error code of UARO - what does it mean?
  • prem mathew May 11, 2010
    Would be good to state also what the problem is, besides the error. Plus the make, model, it would help......
What does error on a viking range mean F03
download the user manual from the makers website usually free to download eric
Dec 24, 2017 | Viking Washing Machines
What does error code "Key Short Err" on Viking dual fuel mean?
Hello. That type of error usually means that there is a shorted button on the control. I don't know the model number so I can't look up the part. The button control panel is usually known as the "user interface" in repair lingo. Be prepared, the user interface panel is normally more expensive than the main control board. If the unit has "soft touch" buttons one of them probably is shorted out(giving the computer the impression that you haven't removed your finger and it's still being pressed). If it's one of the fancy capacitive touch panels(you just touch the glass to select), the circuit board has a defective chip and must be replaced.
Aug 31, 2015 | Viking Kitchen Ranges
I have a Viking Oven and the code F o8 has shown up. What does that mean?
Hall effect sensor in cooling fan issue. Shut down and power up again . Or call tech assist at 888/845-4641. Hope this helps
Oct 20, 2014 | Viking Ovens
Dishwasher Repair
get in touch with the retailer
Oct 19, 2014 | Viking Dishwashers
Husqvarna error code 1
I'm not familiar with that Error. Suggest taking it to an Authorized Viking Dealer for repair. You can find the nearest Dealer from the Viking website - http://www.husqvarnaviking.com/us and click on Locate a Dealer
Feb 14, 2014 | Husqvarna Designer I
Viking spa runs 5 minutes then shuts off
The error code you are getting can be found, I believe, at the following site, Error Codes
Scroll down until you find the Viking Spas.
Rod
US Parts Center
Mar 10, 2013 | Pool & Spa
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
