Question about Kodak EasyShare C633 Digital Camera
Will not turn on
When I try to turn it on a red light by the view finder flashes at me, then it quits. It won't turn on at all!! Even if I replace the batteries.
  • 2 more comments
  • Anonymous Nov 13, 2008
    my ckodak easyshare c633 digital camera does not work even i changed the batteries and it is just dead /what should i do
  • hack12 Nov 19, 2008
    will  not turn on blinks one green then 10 red
  • Anonymous Dec 09, 2008
    When i change the batteries my camera sometimes will not turn on, i have to change them around before it turns on!
  • Anonymous Jan 07, 2009
    yeah sme. i have to keep opening the battery compartment nd moving the batteries then try again nd eventually it goes on. does anyone no wats wrong??
Mine does that when batterries are dead
Posted on Jul 26, 2008
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Air con not accepting remotes
If you have a phone with a camera, look at the infra red LEDs (located at top of remote) through the view finder of camera phone and press the on button of remote. if remote is working you should see the LEDs flash white. If not, then the problem is your remote. IF they do flash, problem could be 1 of 2 things: 1. If you have energy saving light bulbs installed near you a/c, these sometimes interfere with the infra red signal from remote. 2. The remote receiver circuit board of you a/c is stuffed.
Jan 20, 2010 | Heating & Cooling
Red light flashing in view finder. Looks like a bowl with a paintbrush and a line through it. Camera does not record when turned on, have to turn off and on several times before it will possibly record
The red flashing symbol means that the backup battery needs to be replaced. I'm not sure that it is what is preventing recording, but you can change it and see if it works.
The backup battery is a CR2025 button battery. It is located under a square plastic cover, beneath the main battery. Take the main battery off and you should see this cover. The backup battery should be installed with the + facing out.
Dec 29, 2009 | Canon ZR45MC Mini DV Digital Camcorder
Camera will not turn on. As I rotate the selector switch the light flashes at each position. Even when I switch it to off the off light flashes on and off. The screen stays on but it is blank.
Hello, Did you try pressing the little silver button marked "EVP/LCD" it is located at the left of the view finder,This turns the screen on and off.
Hope this takes care of problem.
Best Regards, Russell
Feb 06, 2009 | Kodak EasyShare DX6490 Digital Camera
Dark view in view finder
Sounds like a lens diaphragm problem ( lens stays closed down to F16 and that is why you have a dark viewfinder ). Remove lens and see if you can activate the aperture mechanism via the activator which protrudes from the rear of the lens. You should get nice and brisk action from the aperture . If the movement is sluggish or the lens stays fully closed then your lens needs attention.
Sep 15, 2007 | Nikon N75 35mm SLR Camera
Kodak EasyShare  C633 Digital Camera Logo
132 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
