Question about Mitsubishi VS-45607 45" Rear Projection Television
LINES ACROSS TV
TURN TV ON AND LINES ARE THERE AFTER ABOUT 2 HOURS PICTURE COMES OUT CLEAR AND LINES GO AWAY.
  • 1 more comment
  • zooch Jun 07, 2008
    Same problem just appeared out of no where all of a sudden
  • zooch Jun 14, 2008
    Surely someone has the answer?????
  • americanpit Jun 23, 2008
    turn tv on horizontal lines and looks as though picture is folding in
  • 927 Answers
Good Day, YOU ALL;
Try this: 1. E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
2. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
Also you may poor solder connections on the vertical output IC or on the CONVERGENCE IC's.
Hope this helped, good luck, big IRISH.
Posted on Jul 31, 2008
Screen jumping
this problem coming from 2 parts t.con board or the screen take a chance with t.con board or scrap the tv
Feb 28, 2014 | Westinghouse SK-26H520S 26 in. LCD HDTV
TV comes on with a good clear picture and about 30 to 40 sec goes off.
The tv projection lamp have not been replaced in this tv like the last 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours a day?Yes,than the tv projection lamp life is over.The tv projection lamp,require replacing.
Oct 18, 2010 | Samsung HL-S5087W DLP TV
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
Toshiba 43vs9ua rear projection tv picture problem
I also had a same one but had the same problem. Thinking of throwing it away!
Dec 25, 2007 | Televison & Video
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Dec 20, 2007 | Gateway LCD30TV Television
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
