Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Access to parts in washing machine
I have a frigidaire gallery front load and I need to get at the bearing behind the drum. How do I take the machine apart.
  • 1,028 Answers
2 men 2 hrs minimum tub halves are bolted together and entire assembly will need to be removed bearing is not a service part entire rear shell will need replacing and probably basket also due to shaft scoring better ck for warranty
Posted on Jun 06, 2008
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Gallery top load washer drum turns at half-speed during wash and rinse cycles
Sounds like a professional needs to assess the drum assembly for any balance issues, bearing or pulley concerns or a faulty transmission and motor. Not a DIY job at this point.
Aug 14, 2012 | Frigidaire Washing Machines
Need directions to remove broken drum vane in a Frigidaire Gallery Front loader washer (GLTF2940FS1).
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Jun 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum is loose, struts maybe? springs?frigidaire gallery front load.
this could be the bearings,if you feel a knocking noise when lifting the inner chrome drum up and down then its the bearings,
Jul 06, 2009 | Frigidaire GSTF1670A Front Load Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Black streaks, smudges and dots from drum
take a rag and wipe around front door boot first does any thing come off on rag if this ckd ok does it keep a roaring noise when spinning? if so suspect rear bearing or corrision on spider this is tub support behind basket..ask for estimate before repair as this could result in major expense to repair good luck
May 28, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
129 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
