Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
1GB flash driver
I'm confused as to how this driver works. I will put it in and do I jsut leave it in until the led light goes off.
    Habit-Forming:
  • 111 Answers
The led light will stay on, showing that it is working and connectd... To make sure what you have save to it. Open it up in my computer and see what is on there.
Hope this helps
Posted on Jun 05, 2008
How do I determine if it's the LED Driver or the LED lights that are bad on my LG LED TV?
If it was the LEDs, then you should still have some working. My first thought would be the LED driver circuits.
Best of luck.
Feb 23, 2016 | LG 47" 5700 Series LED HDTV - 47LN5700
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
I need a simple wiring diagram to turn on 40 red leds and 40 green leds on a 9volt battery
Two ways to do it..........
One is a Series circuit, the other is a Parallel circuit.
Of course you can also use a Series/Parallel circuit.
Each LED has a Positive ( + ) connection, and a Negative ( - ) connection.
A) Series circuit:
One side of Switch is connected to Positive ( + ) of the Battery.
The other side goes to the Positive ( + ) of the first LED light.
Then the LED's are connected together in a Series.
Negative of first LED light to Positive of second LED light.
Negative of second LED light to Positive of third LED light.
Negative of third LED light to Positive of Fourth LED light.
And so on, and so on, until you come to No.40 LED light.
It's Negative connects to the Battery.
ONE LED goes bad, and none of them will work.
Old Christmas light strings are set up this way.
B) Parallel Circuit:
Switch to Battery - Positive ( + )
Wire goes from Switch, to 1st LED light's Positive connection ( + )
Then wire from 1st LED positive, to 2nd LED Positive ( + )
Then wire from 2nd LED Positive to 3rd LED Positive.
And so on, and so on, until you reach the 40th LED.
Then wire comes from Negative ( - ) of Battery, to Negative of 1st LED.
Wire from 1st LED to Negative of 2nd LED.
Wire from 2nd LED to Negative of 3rd LED.
Wire from 3rd LED to Negative of 4th LED.
And so on, and so on, until you reach 40th LED.
Wire connects to Negative of 40th LED. Then a wire connects from 40th LED Negative, and goes to Negative of Battery.
http://en.wikipedia.org/wiki/Series_and_parallel_circuits
Series Circuit;
http://en.wikipedia.org/wiki/File:Series_circuit.svg
Over to the Left side you see the Battery symbol. There is no switch in this circuit.
In the Battery symbol, the Longer line represents the Positive pole.
(Positive connection)
Resistors are represented by the squiggly lines. In place of them put your LED lights.
A Switch would go in-between the Battery, and first LED light; on the Positive side.
(ALWAYS put the Switch on the Positive side. Can explain in detail if you need)
[The Top line in the diagram, is the Positive 'wire' ]
http://www.autoshop101.com/trainmodules/elec_circuits/circ114.html
Parallel Circuit:
http://www.autoshop101.com/trainmodules/elec_circuits/circ122.html
In a Parallel circuit, if one LED light goes out, the rest stay on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2013 | Computers & Internet
Anti-theft system will not allow car to start - how do you unlock the anti-theft
if the theft light is was flashing on you, put the key in the ignition and turn all the way until the instrument cluster lights up, just don't start the car. leave it like that for aprox. 10 min. or until light goes out. when that happens, turn of(don't take out keys) and try to start car. hope it works.
Jul 03, 2010 | 1997 Cadillac DeVille
I put the wrong key in my 2000 maxima now the right key wont work. How do I reprogram it.
Check your owners manual. Put the right key in the ignition, turn it on until the gauges light up and leave it for about 10 minutes like that. If it has a security light or a theft light flashing wait until it goes off, then remove the key and try to start it.
Oct 29, 2009 | 2000 Nissan Maxima
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Lights flash on ac rec and rear wiper buttons. Put on new ac com
With my 1998 TC you have to start car turn to cold and fan on high. Tehn hold down the rear wiper and WASH buttons until the lights start flashing differently. Let it run through until only the rear wiper light is blinking. You should here it cycling through the different functions. When it is jsut the rear wiper blink press that button and the system is reset if there are no problems. A low voltafge problem had caused mine to act up.
Aug 05, 2009 | 1998 Chrysler Town & Country
THE EXACT SAME, NO POWER NO GREEN LIGHT
I have a similar problem in that when I turn the switch on the back on, the green led at the front blinks once and then stays dead.
If I put my hand over the IR pod [block all light from it] and then turn the back switch on, the led blinks once and then goes into standby mode and from then I can turn it on normally with the remote etc.
Weird hey.
Jun 28, 2009 | Altec Lansing VS3251 Speaker
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
90 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
