Toshiba Satellite A135-S2276 Notebook Logo
Posted on Jun 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DISPLAY PROBLEM MY laptop screen is appearing blank though my laptop is switched on.I have asus laptop
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Jun 04, 2008
Anonymous
Master
Level 3:
Answers
458
Questions
Helped
242677
Points
1345
Check to see if your Video Card is bad by plugging the laptop into an External Monitor... then press the F5 key to toggle it to the external source...If your PC shows up on the second screen, you have video issues...
New asus R514 laptop , switched it on automatically set up internet connectivity and updated, then screen went blank but mouse works and pointer shows
Try restarting and wait at least 5 minutes to see if the screen appears, if not reboot and run in safe mode and see if you get the same problem, if you don't then your best option is to perform a system restore.
3answers
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
1helpful
Screen goes blank
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
This message appears on the screen after the ASUS screen. Then nothing. Help
In Most cases if a screen can display and shows signs that your laptop was loading then shows nothing later many times your windows may be corrupt or damaged so you will need to re-install windows on your laptop....i would recommend windows xp 2 and just after installing please try installing an anti virus immediately before any other program is added and don't forget to update the anti virus first. Please also give more information on what kind of message appears before the screen goes blank.
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
I have a Toshiba Equium L40-156 laptop.When switching on a message appears saying windows is loading files,the screen then goes blank.
on startup press f8 a screen with a black background and white writing will display select enable vga mode. after windows loads reset display settings
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
PC screen display breaks up
If parts (motherboard) were replaced under warranty, there still could be other issues related to the first issue. For example, it could be a loose cable from the new motherboard to your screen or other issues.
For example, in Control Panel, try turning off any screen savers or power management or saving features.
Have you ran a Dell diagnostic and if so, what does it say?
Here's how:
  1. Restart the computer.
  2. As the computer boots, press < F12 > when the Dell Splash Screen appears
  3. When the Boot menu appears, highlight the Boot to Utility Partition option, or the Diagnostics option and then press < Enter > to start the 32-bit Dell Diagnostics.
3answers
Black screen
just clean your ram and resit it.
If the problem not solved then you are having display adapter problem and you have to send the laptop for repair
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
