Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
No light and buzzing noise
I have a side by side and the freezer side is working just fine, but the fridge side of it has no light or panel lights is barely cooling and makes a buzzing noise coming from the bottom when you open the door, any ideas? any kind of help is appreciated. Thanks.
    Problem Solver:
  • 5 Answers
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Posted on Dec 31, 2008
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Whirlpool gold fridge model GD5SHAXNSOO
Have you got a screw loose. One which holds the door light switch. is it the switch which buzzes?. I had a fridge which didn't get cold. When I scrapped it I found that the retaining ring for the switch was not tight enough and r4ealised that the light had been on when the door was closed.
JennAir JC2289AE Refridgerater Grinding Noise ??
i can't find a diagram on this model.are you sure it is correct.is this the one with the two long slide levers to adjust the temp for fridge and freezer?if so,the sound will be coming from the right in the back.some describe it almost as a motor sound.generally that is the sound of the defrost board.it should not do that.that is a early warning sign of trouble and soon frost will develop on the lower freezer wall.replace the board.if it the one with two nobs on the left for temp adjust,then you probally have a noisy damper(the doorway between the fridge side and freezer that lets in cold)without more info,its hard to say
Jan 14, 2008 | Refrigerators
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
