Question about Maytag Microwave Ovens
On a Jenn-Air Microwave Oven Model JMV8166BA what is an error code E12 indicate?
  • Maytag Master
  • 9,098 Answers
E12 normally indicates a door switch problem. It can be a bad switch or switch mount.
Sometimes it's bogus and you can clear the code by unplugging the oven for a few minutes then resetting the clock.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
How to uninstall an over the range Jenn-air microwave JMV8166BA
Remove two phillips screws from each side of the microwave. One at the very top and one at the very bottom. Remove the front cover. There will be a couple of other screws and metal stops under the microwave that will need to be removed also. After that, the back of the microwave will need to lifted and move forward just a bit to release the back. Pull the microwave forward and toward the left side, enough to be able to reach behind the right side of the oven and unplug the microwave. Remove the microwave. To reinstall, just reverse these steps. It might help to use a mirror and check out the 110v 60Hz socket in the top right corner of the oven that you will need to plug the microwave back into when you replace it.
Jul 17, 2014 | Jenn-Air JMV8166B 950 Watts Convection /...
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Oven works but it no longer is self-cleaning. No
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Sep 10, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Error code E-21 Jenn Air convection microwave
That code says to first check your oven temp. sensor probe connection and ohm it out with an ohm meter, it should read about 1100 ohms at room temp.
If thats ok, then it says the problem is your relay board.
If you need more repair advice help on your appliance, click
Jul 07, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
