Question about Movado 800 Performance watch
Date will not advance on own. you can change it by hand but doesn't change at night stays on same date for days.
  • Anonymous Mar 31, 2014
    If you rotate the hands manually the date will change. The date will not advance automatically.
    Scholar:
  • 101 Answers
One of the wheels of the watch movement has become stuck or broken. You will either need to fix or replace the wheels or movement.
If you have still have warranty card for Movado and within the date range of the models warranty then Movado will repair watch for free if not you will have to have it fixed by Movado or a local jeweler.
Posted on Oct 18, 2010
SOURCE:
How do i get the day to match the date
Here is step by step instruction as well as the picture.
Please click on the link
http://www.michele.com/wcsstore/Michele/images/instructions/michele_instructions.pdf
I hope this will help you resolve the issue.
Thank you for choosing fixya.
Mar 02, 2011 | Michele CSX Diamond watch
My rolex submariner keeps having the wrong date on it. when it turns midnight it stays on the old date and i switch it to the correct one. but when noon rolls around it switches to the day ahead and i once...
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Aug 06, 2009 | Rolex Watches
Date Changes during the day
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Jul 23, 2009 | Seiko SGG786 Watch for Men
How do you set the day/date on a watch????????
Try this solution I posted earlier for a similar problem.
If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Jul 17, 2009 | Seiko Wrist 5 SNKA03K1 Automatic...
Setting the time and date
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
Jul 09, 2009 | Rolex Explorer II 16570 Wrist Watch
Winding and setting the time on a rolex watch
Apr 04, 2009 | Rolex Watches
How do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Apr 04, 2009 | Watches
I need an owner's manual for a Rolex Oyster Perpetual Day-Date. Any idea where I can locate one?
Mar 31, 2009 | Rolex Day-Date President 118238 Wristwatch
Owners manuel
There isn't any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
PS: If you do not have Day function, just ignore it - the rest is the same.
Mar 18, 2009 | Watches
How to adjust day date on older rolex perpetual day date watch
Mar 06, 2009 | Rolex Datejust SS
Movado 800 Performance watch Logo
246 people viewed this question
Top Movado Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Movado Watch Expert? Answer questions, earn points and help others
