Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Sooting of pans in oven
Hi: I called the GE toll free number to ask how to get an LP gas orifice for and how to change the orifice for our ge xl44 oven, since we had to change the top burners from natural gas to LP, and since the LP orifices were supplied on the top, but no oven orifice. The customer rep told me that there were no orifices for the xl44 range's oven and that you only need to adjust the toggle type mini lever at the top of the back of the range...LOL!! It is not correcting the problem - unless we like to cook at less than 150 degrees. Can you help? I still get soot at any temperature above the 100 ro 150 degree range, and that is not only ridiculously slow, it's downright unsafe!!! Thx
If you adjust the toggle type mini lever to a lower pressure so that the flame is just under licking up through the bottom of the oven and then adjust the air mixture to eliminate all but about an inch of yellow flame it should get rid of the soot.
You want to be sure that the flame is not pulling away from the middle bar where the gas comes out ( a little pull away is ok) and that there is not too much yellow flame. Find the happy medium and you should be good to go.
You may have to adjust the lever and the air mixture a few times before you get it right.
To adjust the air mixture you will need to remove the cover plate at the bottom towards the back, then loosen (no need to remove it) the one phillips head screw holding the air mixture cover in place. adjust the air mixture by moving the cover left or right letting in more air or restricting the flow of air more.
BE CAREFUL, to determine if the mixture is right you will have to turn on the oven bruner and everything will be hot. Wear protective clothing and BE CAREFUL to not burn yourself.
You can find a manual for this model by searching google for "ge xl44 manual". It was the first return when I did the search.
Here is a link http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=ITEMID&itemid=003678171 if they leave it, otherwise you will have to search for it yourself. They explain how to adjust the air mixture in this pdf on pages 35 - 38.
Posted on Nov 26, 2008
    President:
  • 1,314 Answers
Yes i can help locate the pressure regulater where the gas line hooks up there will be a square lookin nut on top of it unscrew it and in side will be an insert and a spring one side of the insert will have nat thats for natural gas flip it over and the other will say lp then screw the nut back down should be fine o tay lol
Posted on Jun 05, 2008
  • robert samples Jun 05, 2008
    natural and lp operate on different pressures flipping the in sert over will change the pressure read your owners manuel about converting to lp all ranges are shipped natural gas
Convert GE XL44 from LP to gas
replace original orifices and adjust regulator to natural gas
Dec 30, 2009 | Kitchen Ranges
I have a GE XL44 and i need to change it over to lp. none of the orifices for LP are with the stove. Where can i get them and what do i need to do with the oven?
Repairclinc.com has LP orifice spuds listed for about $1.80 a piece. The item number is 1263006. Appliancepartspros.com also has them listed for about $1.63 a piece. The part number is AP3994353. You need to purchase one for each surface burner.
As for the oven. Turn the gas supply off and locate the pressure regulator. Remove the cap on the regulator and remove the orifice fitting inside. Flip the orifice over and reinsert it. Place the cap back on the regulator and it is now ready for LP use.
If you have any questions, please let me know. I hope this helps you.
Dec 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need a conversion kit for my GE XL44 range
go to www.marcone.com they should be able to help you call the toll free number
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 propane to natural gas conversion.
Hi, You will need to use a 1/2" wrench and turn the orfice for the oven 2 turns counter clockwise.
Make sure you flip the plunger over on the regulator also.
After doing these things, watch the flame in the oven to make sure no other adjustment is needed.
Please let me know if this helps or if I can assist you further.
Vic
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Black soot on bottoms of pans
Wellif you uninstalled and reinstalled the same appliance it should work the same.. thats weird that it changed. however the black soot is usually from flames that are to high. you could try tightening down the orifice where the gas comes out.
Dec 01, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
401 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
