Question about Lexmark X1270 All-In-One InkJet Printer
Can't get it Fax
Help, it is doing everything properly except for the fax machine.
  • Anonymous Jun 09, 2008
    aioc exe stop warking
  • elisaenid Jun 12, 2008
    yes
  • 48 Answers
What modem are u suing..is it internal or external...?
what type of phone line do u have....DSL or normal phone line...?
Do u have an answering mec or a voice mail....?
The connections are simple.....
Phone line from the walll outlet should directly go to the Line jack behind the printer--and then from Ext jack from ur printer to phone....
Send me the details and ill let u know what setting u need to make
Posted on Jun 18, 2008
Everything on my canon Pixma 492 wireless machine is working except the fax. What should I do?
You cannot use a fax wirelessly. The machine must be physically connect to a phone/fax line in order to send and receive faxes. If the machince is connect to a jackpoint on an ADSL broadband system, you MUST fit a line filter between the machine and the jackpoint.
Jan 19, 2017 | Canon PIXMA Office Equipment & Supplies
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
Canon ImageRunner 1025if won't fax to #s, only email
Try to connect simple phone to fax line and try to dial a number of fax that you are calling from machine.If the line is ok then do the next:
press MENU and # ( service mode) with cursors go to clear, ok, clear all and ok.Turn off and on.
If that doesnt help call service.
Be carefull: the tel. line to fax machine must be connected in L slot, not in small picture of telephone.
Jun 15, 2010 | Canon Imagerunner 1025IF Grayscale Copier
I got a fax number from telstra and got told that my home phone wouldnt be interupted if they come through the same line my home number is different to the fax number but my home phone wont except messages...
both the numbers should be same otherwise the fax machine will not work properly ..............you have to ask the person who gave this machine for a change of number
please rate me
Jul 14, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Everything works fine except receiving a fax.
Check the answer mode, you should easily be able to see it in the display when in idle mode.
The CD is not needed for the machine to perform actions not requiring a computer, e.g. sending/recieving faxes.
Also, check the phone cable connection so that it's connected to the LINE outlet, and not the EXT one. Connecting it to the wrong contact would still make the machine ring (as it detects the "call" on the line) but unable to lift the call since the modem communicates only through the LINE port.
You could troubleshoot by letting the machine be alone on the line to see if it can send and/or recieve faxes.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Can fax out but not receive faxes
-You should have a number (fax number) for it in order to be able to receive incoming fax.
Good luck
Mai
Jan 18, 2018 | HP Photosmart C6180 All-In-One InkJet...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
I have a Canon MP830-All in one. It does everything except send/receive faxes. The line has been checked out. If I connect it to the phone line, it just clicks. I have rebooted and unplugged and...
Your fax machine is not getting a dial-tone.
Plug a regular phone into the wall jack and listen for a dial-tone
Make sure the phone line is hooked into the LINE port of your fax machine.
Unplug the power cord for 10 seconds.
Do you have a DSL phone line?
Oct 21, 2008 | Canon Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
