Question about Hotpoint FFA70 Bottom Freezer Refrigerator
There is power as the fridge is ok but the freezer is not frosting
I have checked our power supply connection and there is no problem at all. The upper fridge is working alright but the food in the freezer is not frozen at all, instead it was defrosted and warm. I also noticed that there is the red light been on -Freezer High Tempreture. What does it meant and how to solve this problem?
Esto es un ejemplo de texto, con un video de prueba
Esto es una prueba
Posted on Jun 04, 2008
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Belling bk29 fridge freezer. freezer working but fridge not working. compressor running, thermostat set to 5, light working ok, defrost switch off.
Sep 08, 2011 | Refrigerators
Hotpoint ff73 fridge temp unstable some times ok other times not chilling at all temp gauge showing different reading and freezer sometimes drops down to minus 30.in the cabinet
Possible that the thermostat is faulty or there is a weak connection due to frost wearing- out the connection of the thermostat. Shut down the fridge and allow time for the frost to melt off, then check the connections of the thermostat and to the defrost timer, open the freezer rear panel to check this out.
If not the main relay also must be checked, Hope there is no interuption of the mains power.
Sep 08, 2011 | Hotpoint Refrigerators
FREEZER HAS TOO MUCH FROST AND COOLING, MIDDLE AND LOWER SIDE HAS LESS COOLING WHIRLPOOL 175 MODEL
More freezing on the freezer means there is frosting Now you have observed that the fridge after working for about 24 hours does not cool , check if the fridge cuts off. If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
Aug 24, 2011 | Refrigerators
My LG Refrigarator with a top freezer and water dispenser is frosting on the freezer and the refrigerator is warm
Top of Form
Aug 12, 2011 | LG Refrigerators
KENMORE REFRIGATOR FREEZER THE FREEZER WORKS FINE THE REFRIGATOR IS WARM
Jul 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
The freezer cools half way top, below is warm.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
