Question about ASUS A6U Notebook
Display problem i have a problem...i am not getting a proper display...when the laptop is switched on the power is on but the screen is not functioning...can u please suggest a service centr in mumbai
  • gexsmorris Nov 23, 2008
    when i turn on my lapptop at times the laptop will indercates it on however the screen is off but blacklight is on it takes about 20 goes for it to come on
  • 86 Answers
Hi
I think in your laptop OS is vista,it means ;aptop is no sleep mode,
Press the key Alt + enter key & check
Posted on Jun 07, 2008
My pc is not booting
Hi eric,
Try connecting your laptop to a different monitor to see if it works properly. If it does, then there is most likely a problem with the laptop display assembly. If the external monitor does not work, then the problem may lie with the laptop's video card.
If you power on the computer and the display is black, make sure the computer is booting up. You can do so by checking the LED lights, listening to the fan, and/or listening for the Windows boot up sound. If either of these are functioning properly, your screen may not be working properly. You may take a look at ourToshiba Satellite LCD installation guide to help you replace the screen.Hope this solves your problem please rate my solution if it helped you.
Note:-Make sure that you are careful while working with the screen or Motherboard as there may be chances of shock if you are a novice i recommend to get it serviced by a professional.
Regards,
bonefirediv.
Apr 18, 2014 | Toshiba Satellite Computers & Internet
What causes laptos to not show display despite showing that they have switched on?
Step 1:
The display on your laptop is the interface through which you interact with and control your computer. If it is not working, your laptop will become virtually impossible to use. A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display. Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord. If the laptop is out of power, the display will not work. This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power. Check to make sure the power cord is plugged in and that the laptop has power. Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained. Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning. Press and hold the "Power" button on your laptop to reboot your computer. If the problem was a malfunctioning program, the display will turn on after the computer restarts. Check the brightness level of the display. If the level is too low, the screen will appear dark. The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys. Press the key with the larger icon to increase the brightness level. Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness. Check the display closed switch. Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode. If the switch gets clogged with dirt, it may get stuck in the closed position. This will result in dark display even when the lid is open. The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation. Plug an external monitor into your laptop. If the problem is not software related, the external monitor will display the laptop's screen. Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop. Press and hold the "Fn" key while simultaneously pressing the "F8" key. The video output will be directed to the external monitor if there is a hardware problem.
b>
Feb 21, 2013 | Toshiba Satellite Computers & Internet
Lcd screen not working
Step 1:
Feb 20, 2013 | Computers & Internet
My hp compaq model 510 is not working with projector.projector is not working on this laptop plz provide a proper solution.
You are not providing enough information to help you.
Have you set the display to use an external monitor or dual monitor? That is how laptops work with projectors. You normally can set the system for dual display and either mirror the displays or use the second display (projector) for power point or other presentation.
If this does not fix the problem, post more information on why it is not working for you.
Jun 23, 2011 | HP 510 Notebook
My hp DV9810US Laptop computer displays a blank screen (black) when powering up. All led lights appear to function normally. The hdd is heard spinning and I can hear the windows jingle after a few minutes...
Your HP laptop could have a backlight problem. This could be caused by a faulty inverter or a faulty CCFL lamp. please click on this link and follow my instructions to determine the exact fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 24, 2010 | HP Pavilion dv9810US Notebook
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Black screen display after switching on
Try restarting without the battery ...just the power adapter.
May 22, 2009 | Dell Inspiron 5150 Notebook
The display on myy HP dv1000 laptop went black.
Sounds like its either going to be a bad display or the inverter underneath the display is not providing enough power to the display to light up properly. Only way to troubleshoot it is to swap out the inverter and/or the inverter to designate the exact problem.
Feb 09, 2009 | HP Pavilion dv1000 Notebook
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Screen Don't Comes On Anymore
Have you tried plugging an external monitor into the VGA connector on the back? This would narrow down the problem to either the video card/motherboard or the LCD display itself.
There are several possible defects- as above, the display, motherboard component, video section.
Also, first check the LCD/CRT switching function. On many laptops, there is a function (FN) key which is pressed at the same time as one of the number/function keys (the uppermost row of keys), and this combo will switch display from LCD to CRT & both.
Feb 28, 2008 | IBM ThinkPad T42 Notebook
ASUS A6U Notebook Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
