Question about Syntax SV266A SKA KT266A Motherboard
What is the pin diagram for audio in /out
I have the board and xp running but cant find a pin layout for the audio pins.l/out /r/out mic gnd etc
    Genius:
  • 1,027 Answers
what is the pin diagram for audio in /out - f11caf6.jpg
Audio front header
Posted on Jun 05, 2008
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for...
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Sep 03, 2010 | ASUS Computers & Internet
I have an LGA 775 motherboard and I'm looking for the audio pin layout on J11 My pins are mic in, mic bias, gnd, spkoutL, spkoutR (last two have piggybacks with the same label)
I think your J11 is for front or rear speaker outputs.
The mic should plug directly to the board with no problems
If you have problems, you should be able to get a board layout at Abit.com
Nov 29, 2009 | Abit GD8 Pro Motherboard
What is the pin layout for the J30 pin set on the Dragon KT 600 plus?
Mic & LED connector J30;
Pin1 Line_Out_L
Pin2 GND
Pin3 Lin_Out_R
Pin4 GND
Pin5 MIC IN2
Pin6 GND
Pin7 LAN_Active_LED
Pin8 VCC
Sep 23, 2009 | Soyo KT600 Dragon Plus Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Syntax SV266A SKA KT266A Motherboard Logo
170 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
