Question about Denon AVR-1906 Receiver
Denon AVR-1906 Receiver is hooked up to Sony DVD player with optical cable, and 5.1 speaker system (Gallo Nucleus Micro). When DVD or CD input is set to "anolog" stereo, sound is fine, but when set to 5 channel stereo or Dolby ProLocic (digital) for movies, there is so much interference or "static" noise that it is unusable. I tried moving the DVD player and receiver apart, and to different locations in the room, and also connected with coax cable instead, but no difference. Am I doing something wrong, or is the receiver defect?
  • 25 more comments
  • JustinCarl Jun 04, 2008
    Thanks. Believe me, I know this manual pretty much inside-out by now. Is there anything specific I should look at?
    Any movie DVD or music CD is doing the same thing. It works fine if I connect the DVD player just with stereo component cables or if I keep the setting on plain "stereo". Any surround sound setting creates the same problem. Other players (e.g. ipod) connected in analog mode work fine as well.
  • JustinCarl Jun 07, 2008
    I tried the speakers separately, no difference. I left the receiver off overnight and realized that it will work fine after turning it back on, but after running for about 1/2 hour of DVD playing, the crackling noise starts and then gets more frequent. After some hours the loud static noise will be constant, even if the DVD player is turned off. I saw today that the manufacturer's seal on the chassis was broken, so I assume somebody "worked" on this unit (I bought it on ebay, supposedly in perfect and tested working condition.)
  • Anonymous Mar 11, 2014
    When I go over small bumps in my 2007 VW Jetta, my car makes a squeaky grinding sound. It only happens when I go over a bump. Does anyone know what this is?
    wont let me play sims 3 freeplay
    i have accidently locked my ge corded phone. how to unlock the same. kindly resolve
    water leaking into leg cup on bottom
    I need the tv codes to program my emerson tv
    tempurature sensor in 2005 Volkswagon jetta
    My break is soft and my front wheel is always hot after driving my car
    THE CAR WILL NOT START.IT IS GETING FULE BUT NO SPARK.ALSO CHECK ENGINE DOES NOT COME ON WHEN KEY IS TURNED TO THE RUN POSITION.ALSO THERE WAS ABOUT 2IN.OF WATER IN THE PASSENGER SIDE FROM RAIN.REPLACE ECU THAT CAME FROM A 1991 ACCORD EX BUT NO CHANGE. NO START NO CHECK ENGINE LIGHT
    how to delete gmail account
    Battery has low charge. I jumped car off. When I removed cables the engine died.
    i have to push the clutch all the way to the floor to start my car now even if i push it to the floor it still want start
    My Husband inherited a Remington .22 cal Long Pump Rifle with alot of info on the barrel. This is the closest # we feel may be the serial number {RW 458756} can you help us find more info. on this firearm? Thanks for your time and help.
    should i have to pump the gas pedal while trying to start the car
    front seats stuck in one spot
    when I remove the bottom filter from my maytag washer the holes are plugged with a white hardened residue. what is it and how due I clean it
    hi can u plz help me unlock my nokia 3555 this is my ime # 353530020299706
    I BROKE THE SECTION THAT HOLDS THE WIPER TO THE
    ASSEMBLY WHILE TRYING TO REPLACE THE BLADE
    how do you connect a wireless playstation 3 rock candy controller
    misfires
    Won't stay running
    Where to buy washing machine hose extensions
    wheres fuse box under hood in 1999 beetle
    I WANT MY HOME PAGE TO BE GOOGLE
  • Anonymous Mar 12, 2014
    I have a 2005 chev impala and it keeps overheating i replaced waterpump and thermostat and new hoses and it is still overheating what is wrong
  • 3,037 Answers
It sounds like the receiver has a loose internal or unprotected part causing interference most likely a defect, I would take it back and get a different one if you can and then let us know if the same thing happens. If it does then you have other problems but I think that you just have a defective unit. Let me know how this goes and if you need further help, just ask
good luck
Posted on Jun 04, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 04, 2008
    If two different cables are doing the same thing, It would most likely be internal and not something you want to try and fix, what else it could be are the speakers causing this, try hooking up only one speaker at a time and see if you get this problem
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    So obviously some component isn't able to handle the heat after a while in the circuitry. Start by checking the board and power supply and anything that may have been replaced
  • Benjamin Patri
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jun 04, 2008
    Make sure you have correct connections as described on page 13.
    Novelist:
  • 142 Answers
The DVD's that your are playing , check whether they are made to support sounds.
If not , then you will face noise problems with the DVD
Try to play other DVD as well
    Sergeant:
    Champion:
  • 230 Answers
It is receiver defect only i think
  • balachander megavarnam
    balachander megavarnam Jun 04, 2008
    the receiver should be tuned to get the good sound
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
Dec 09, 2012 | Denon AVR-682 Receiver
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
No sound fom optical input
Do you have your TV hooked up, so you can see the AVR-4800 system menu on its screen (if not, see the manual). You need to go down to the digital input menu item where you associate each component with its input source, whether it is coax, optical 1, optical 2, ..., etc.
Dec 07, 2008 | Denon AVR-4800 Receiver
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
Dec 31, 2007 | Denon AVR588 Receiver
Denon AVR-1906 Receiver Logo
259 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
