Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Eureka Boss - no suction in upright postion
Been having the same problem since we bought it a few months ago. The attachment has suction, but no suction in upright position. Have cleaned everything - several times. I'm tired of vacuuming bent over using the attachment only~!! What is the cause and if I need servicing - how much can I expect to pay? I bought this vacuum because it was recommended by consumer reports, but regret it.
  • 3 more comments
  • EurekaBoss Jul 06, 2008
    I've lost suction when in floor mode. Hose mode works fine, and the brush is still spinning. There's just no suction and the hair just stays on the carpet.
  • Anonymous Oct 09, 2008
    i also have no suction help
  • i_killed_ken Dec 07, 2008
    I have the exact same problem, it's less than a month old!
  • mandimorris0 Feb 23, 2009
    My vacuum will not pick up when using it upright. the hose works fine. it is connected just fine.
  • jaimieq Mar 04, 2009
    Same thing happened to me.  I owned it less than a week.  It shut off after my kids tried vacuuming up a shoe string.  The suction automatically shut off and the string didn't get stuck in it, but now the suction won't go back on.  The hose works fine though.  And it's connected properly...
  • 64 Answers
When mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Posted on Dec 31, 2008
SOURCE:
I have a bravo 2 eureka bagged upright suction is very bad changed bag cleaned roller still bad what should i do next
Replace the belt if it is over a few months old. Even if the suction is great it won't pick up dirt very well if the belt is stretched out.
Oct 28, 2017 | Eureka Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Bare floor selection still rotates brushes
Your switch should have 2 different on positions. One for simple suction and one to engage the beater. The setting without the beater being engaged should be first position from off and the beater would be second position
Jan 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
New vacuum doesn't pick up....
bockage on the pipe bend.open and clean out.
Jul 19, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Dirt does not go in the dustdup
Take off the front top filter (the clear plastic peice where it says eureka) there should be two filters inside, the bit of foam and the peice it's attached to.
I clean both parts in warm soapy water and let dry, that always fixes the problem for me.
Sep 07, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
817 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
