Question about Philips 42PF9630A 42 in. Plasma Television
How to set up high definition xbox with flatTv
Theres no more places to put in the extra HD wires from the x-box, do i need to buy somthing?
  • 53 Answers
If your talking HDMI cables yes you can go Cablemart.com and get HDMI splitter boxes. a slew of additional parts and they are about the cheapest and the best built.
Have two 50" HDMI cable from them.
Posted on Jun 04, 2008
I brought a 43 in Vizio D43n. I have standard cable box not HD.Can I just use it with this TV ? Or do I have to shell out an extra $ 10.00 a month?
Hiya!
The simple answer is yes
All newer TVs play digital stations by default
Even on good ol' 'antenna' setting
Nov 20, 2016 | Vizio Televison & Video
Tip
How to Rip/encode DVD to WMV HD for HDTV, Xbox 360, PS3
Quoted from: http://www.daniusoft.com/convertdvd/dvd-to-wmv-hd.html
Backup DVD to WMV is common with arising portable multimedia players. Then how about DVD to WMV HD, are you catching up with the new high definition trend? With more and more people around talking about DVD to WMV HD encoder, do you curious about what exactly is WMV HD, WMV HD encoder and why DVD to WMV HD?
What is WMV HD and what makes it different from WMV?
WMV HD is Windows Media High Definition Video, and the difference between WMV HD and WMV comes down to its video resolution. Standard definition we usually see has at most 480 visible lines of detail, whereas high definition video has as many as 1,080.
Standard Definition Video High Definition Video 480p and lower resolution From 720p up to 1080p resolution for now Useful Encoders needed for WMV HD
Windows Media Video HD (WMV HD) can be encoded with a variety of programs such as Windows Media Encoder, Windows Movie Maker, and Microsoft Expression Encoder. When encoding, it has been recommended by these programs that you use the original file for best results.
Free WMV HD Demos you can downlaod
WMV HD Content Showcase is what Microsoft Windows Media provided for you to download high definition video to have a try. FYI, Windows Media Audio and Video 9 Series is a breakthrough set of codecs that enables multichannel audio and high definition (HD) video at resolutions up to 1080p.
Why should you convert DVD to WMV HD?
You may complain that the video quality is not as clean as the original DVD after ripping DVD to standard video. For an ordinary DVD movie is often 7-8 GB in size, if we convert them to standard video formats the size would be hundreds of MB, so we have to face the problem that the code compress process would destroy most of unimportant data and the video quality get bad. Then what can we do to resolve this issue? The answer is to convert DVD to WMV HD, for these HD videos are often bigger than standard video and decrease the video damage. Thus, the WMV HD video seems to be lossless compared with the original DVD.
How to convert DVD to WMV HD?
The self-explaining interface allows you to convert DVD to WMV HD within 4 easy steps.
Step 1: Download, install and launch DVD to WMV HD Converter - DVD Ripper software
Step 2: Load DVD, select output format and set destination folder
Click ''Load DVD' button to add the DVD file. You can also click 'Load File' to add DVD/IFO from your hard disk. Then click "Profile" to select "HD WMV Video" as the output format to keep the movies in high definition, so you can play them via HD Media Player such as HDTV, Xbox 360, PS3, etc.
Step 3: Set advanced settings
Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio, etc.
Step 4: Start to convert
Finally, click "Start" button to start converting DVD to WMV HD. The output WMV HD files can be found by clicking on the button "Find Target". After that, you can copy these files via USB to your hard drives, and plug in it to HD Media Player like HDTV, Xbox 360, PS3 to enjoy.
And you may see the edit part in this program, yes, it enables you to do simple editing if you need:
So just enjoy your WMV HD video with this DVD to WMV HD Converter.
Download Daniusoft DVD Ripper Now !
on Mar 24, 2010 | Computers & Internet
How can I get high definition on the tv? I have it set to receive the signal from my cable tv company but it transmits only a regular signal.
Check these things to solve this problem:
Do you have an High Definition TV? If you bough it recently, then you probably do. If you are unsure, look on the back of the TV for the model numbe and search on Google to read find information about he model of TV you have. If you don't have an HD TV, you will need to upgrade if you want High Definition.
Is the TV connected to the cable box with an HDMI or Composite cable?
You can order a cheap HDMI cable at Monoprice.com.
If you are using old style AV cables (red, yellow, white) then you will not get an HD signal from the cable box.
Check the TV settings to make sure it is set to display in HD. Look in the manual for help here. It is probably in the Input Settings.
You will need to call your cable company and make sure you are getting HD service. If you are not the you will only get Standard Definition. You may have to pay more or upgrade your cable box.
Mar 05, 2011 | Televison & Video
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
Mar 02, 2011 | Microsoft Xbox 360 Console
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
Just set up my new xbox 360. My TV is not HD and I have an antenna and hd converter box. Which does not seem to connect to the xbox console in any way. It seems like my wireless device linked up but I...
I'm not sure exactly what the problem might be, but if you try turning off the x-box and looking at the back, the A/V cables that come out of the back (shaped like a trapezoid where you plug it in) and they should be plugged into your TV.
If your TV uses the Red, White, and Yellow cable side, make sure the switch on the other end of the cable where it plugs into the back of the x-box is switched to "TV".
If your TV has component input "Red, Blue, and Green" make sure you switch it to "HDTV" and you'll also have to connect the red and white (left and right) audio cables.
Your HDTV digital tuner/antenna probably won't be the place to connect them.
If you do not have either cable setups on the back of your TV, you may have to go to an electronics store and purchase an A/V converter box or connector. They are not too expensive.
If you have a little extra cash to spend, I'd recommend getting a decent size LCD flat panel HDTV. Just make sure you NEVER buy a PLASMA screen to play VIDEO GAMES on (video games will destroy the screen and leave you with burn-in or ghosting). Although they are nice for movies and slightly cheaper.
I hope I could help you.
Jan 06, 2009 | Microsoft Xbox 360 Console
Audio problems for HD part fine for non hd
I put this in your first post but this is off of the Best Buy Website, looks like this is your problem
Built-In HDTV Tuner:
Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming.
Apr 02, 2008 | Insignia LCDTV26 26 in. Television
Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Feb 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
High definition cable hookup
There is a switch on the 360 hd cables themselves it is a slider to go from TV to HD it is right where the cable plugs into the 360...switch towards 360 is tv and away is HD. Hope this is what you needed.
Feb 06, 2008 | Akai PT5250A Television
Mitsubishi vs-45603
This set is not HD capable.
When all signals are supposed to go to High Def., there is supposed to be a box that will convert the signal from 1080i to 480i.
I'm not sure how it will look, but, the down converted signal seems to look good for now.
The new technology is coming down in price and the new features are coming at us at record speed.
For instance:
The new tuners are capable of receiving local high definition stations using rabbit ears.
You don't need a cable box to receive all stations (except premium stations such as HBO) including High Definition if the turner has a "Clear QAM" tuner.
LEDs being used in LCD and DLP make them less vulnerable to loss of lamps prematurely and a heartier set.
LCDs and DLPs are becoming the set of choice due to contrast ratios as high as 100,000 to one and unlimited color.
A new type of set is just around the corner using laser technology (from what I have been told by manugactures).
In conclusion:
Your set is not HD, but, it should still operate when or if the change does take place. You may need to get more equipment to help with this change and it may cost more than buying a new set.
Nov 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Philips 42PF9630A 42 in. Plasma Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
