Question about Dell PowerConnect 2716 16-Port Gigabit Ethernet Web-Managed Switch with 3-Year NBD Advanced Exchange Serv... (P2763NP)
PC2716 Connectivity I have a PC2716 connected using Cat5 cable to a Laptop with a static address on the laptop of 192.168.2.5 / 255.255.255.0 I can't ping or URL access 192.168.2.1 to cahnge the IP Address.
    Novelist:
  • 142 Answers
Goto start
Open control panel
Open network connection (XP)
Right click on Local Area connection
Goto properties
click on Internet protocol TCP/IP
Click on properties
Try to change the Ip address on that window
If it does not make any difference then TRy to disable the firewall that is installed on the computer.
Posted on Jun 04, 2008
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
Getting 169.254...
possibly cat5 cable problem or your DWL - 2100AP is only on wireless mode.
please check and put on mixed mode also.
Mar 08, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Unable to connect to the network on a SSC21web monitor
is this poe cam? cable footage over 300 ft needs cat5 extender if fiber check media converter to see if single or multimode also check media converter for tx/rx or using cat5 b crossover cable connect directly to laptop type in ip in command bar enter
Oct 12, 2009 | Samsung Weather Resistant Security Camera...
My laptop cannot identify a network.it can connect to a network but cannot identify the network
you must be using vista...? Do you have internet connectivity? If you do have connection i wouldn't worry about identifing the network. If you cannot access the internet and the connection says something like limited or no connectivity, take the subnet of your modem (or router whatever the case may be) and static your NIC with a specific IP address.
Subnet? http://ask-leo.com/how_do_i_determine_the_subnet_mask_im_supposed_to_use.html
Static? http://hubpages.com/hub/How-to-assign-a-Static-IP-addess-on-WinXP
If none of this works i offer tech support walkthroughs at http://www.hoosierpcrepair.com
Apr 15, 2009 | Toshiba Satellite A200-0ET00X Notebook
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
My network says that it can't find the internal wireless adapter
You may have to reboot your PC and try to connect again.
If you have "Viewed all available networks" and tried to connect to your Wireless network but cannot what kind of error message are you getting ?
To quickly find out if you have Internet Connectivity coming in at all from your Internet Service Provider turn off your wireless switch on your laptop and try to connect a cat5 directly from your PC ( connect cat5 cable to what looks like a slightly larger telephone jack on the side or back of your laptop) to the back of your router and see if you browse the internet. You may have to reset your router (unplug and plug)
Jan 10, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
No connectivity from 1 laptop but connectivity with another`
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
May 02, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dell PowerConnect 2716 16-Port Gigabit Ethernet Web-Managed Switch with 3-Year NBD Advanced Exchange Serv... (P2763NP) Logo
302 people viewed this question
Alun Cox
