Question about Samsung Computers & Internet
No access to my internal drive
I cannot read or write on the drive, but it is recognised
at startup .If I install another drive and want to boot
from it, the PC hangs as long as the previous one is connected
thank you for assistance
  • Brian Canute May 11, 2010
    have you formated the drive
  • 1,183 Answers
If after disconnecting the older drive the new drive is working.
This would only suggest that your old harddrive is already bad or going bad.
Try connecting the drive with the CDROM drive cable ,ie swap the cables around and then check , If still no go, its time to replace the same.
Thanks
Mandeep
Posted on Jun 04, 2008
    Novelist:
  • 142 Answers
Have you formatted the drive?
if yes then , Windows has to be reinstalled and if no then open cabinet of the computer
and make sure you have set the drive as a Master drive and not the slave on the main IDE cable
THE COMOUTER READS NO OPERATING SYSTEM I INSTALL IT WITH NO OS THE COMPUTER READS THE DRIVE BUT I CAN NOT INSTALL AN OPERATING SYSTEM
  • You should have an operating system install disk (or USB drive.)
  • Restart the computer and press whatever key gets you into Startup (typically F2 or Del.) You *may* have an option that says "Boot menu" that has another key (such as F12.) If you have that, use it.
  • Find something in your BIOS that mentions "Boot order" or "Boot priority."
  • If you have a CD, make your CD the first boot device. If you're booting from USB, make it your first device.
  • Make sure your install media is in the computer, save and exit.
  • The computer should now boot from the install drive and put the operating system on the hard drive.
Mar 24, 2016 | Maxtor Hard Drive
Tip
A boot disk (startup disk) and why you need it?
The Windows installation disc contains the files necessary to start Windows, so it is itself a boot disk. A boot disk is actually not a computer disk in the shape of a boot. If it was, most disk drives would have a difficult time reading it. Instead, a boot disk is a disk that a computer can start up or "boot" from. If a problem is preventing Windows from starting, you can use the installation CD to start Windows. The installation CD also contains Startup Repair, which you can use to repair Windows if a problem prevents it from starting correctly. Startup Repair can automatically fix many of the problems that in the past required a boot disk to fix.
A boot disk (sometimes called a startup disk) is a type of removable media, such as a floppy disk or a CD, that contains startup files that your computer can use to start Windows. CD and DVD boot disks are often used to start up a computer when the operating system on the internal hard drive won't load.The startup files are also stored on your computer's hard disk, but if those startup files become damaged, you can use the files on a boot disk to start Windows
Earlier operating systems that used the FAT or FAT32 file systems, such as Windows 95 and Windows 98, a boot disk was especially useful because it allowed a person to access files on a hard disk even if Windows was unable to start. This ability also represented a security risk, because anyone with a boot disk and access to the computer could start the computer and access any file. Hard disks formatted with NTFS have built-in security features that prevent using a boot disk to access files..
Let looks at some useful "boot CD downloads" to create one for Windows OS,s.
1-Ultimate Boot CD for Windows - This BartPE-based boot disc comes with a huge selection of tools to access your data and get your PC booting properly again. Some of them are even useful.UBCD takes a long time to load and asks you some odd questions before it's finally up. But once it's there, you can edit the Windows Registry (yes, the one on the hard drive) in RegEdit, recover deleted files, and even run benchmarks. setting up UBCD is identical to creating a BartPE disc--with the same possibility of failure. But when it works, you get a lot more.Price: Free
Download Ultimate Boot CD for Windows.
2-Puppy Linux - A third party application to create a boot CD using Linux and great for accessing NTFS-formatted hard drives--especially if you're not comfortable with Linux's whole mount concept. Just open the Drives window and select a drive, and Puppy will mount it for you--in read/write mode, if possible.Puppy will mounting the drive with read/write permissions and you not only can copy your files elsewhere, but you can also edit them. Puppy Linux comes with AbiWord, which supports .doc files, and Gnumeric, which supports .xls. And even if it mounts read-only, you can still copy the files to an external drive, most of which are formatted in the universally accessible FAT32 file system.
But be careful how you click. Actions that take double-clicks in Windows, such as opening a file, take only one in Puppy.
Price: Free
Download Puppy Linux.
3-BartPE - The BartPE operating system makes a pretty good boot disc on its own, getting you into Windows and letting you access your drive. It doesn't have much in the way of repair utilities, but it has chkdsk, which should probably be the first one you try.To create a CD, the program needs the Windows 2000 or XP installation files. One place you're sure to find them is an actual Windows installation CD-ROM. But the recovery disc that came with your PC probably doesn't have them.
Luckily, if your PC came with XP installed (and thus, not with a true XP CD), the necessary files are probably in a folder called C:\Windows\i386. But I do mean probably, not definitely. However, since the PE Builder is free, you're not losing much if it can't create a disc.
Price: Free
Download BartPE.
4-Vista Recovery Disc - a unique distribution of Microsoft's own recovery tools.This Recovery Disc is basically a Vista installation disc minus the install files. It even has an "Install now" button that asks for a Product Key before failing. You're better off clicking the Repair your computer button. Among its Vista-only options are a tool for diagnosing and fixing startup problems, a version of System Restore that uses restore points on the hard drive, the restore portions of Vista's backup program, and a memory diagnostic tool. Price: Free
Download Vista Recovery Disc.
5-Trinity Rescue Kit - TRK's command line interface could humble anyone but the most devoted Linux geek.
If you take the time to read the 46-page documentation and learn the program, you'll be rewarded next time disaster strikes. Among the tools that will be at your disposal are a script that runs 4 different malware scanners, a tool for resetting passwords, a Registry editor, a program that clones an NTFS partition to another PC over a network, a mass undeleter that tries to recover every deleted file on the drive, several tools for recovering data off a formatted or dying disk, two tools for fixing master boot record repair programs, and hardware diagnostics.
Price: Free
Download Trinity Rescue Kit.
Hope that you understand the benefits of having a boot disk on your wardrobe.
on Jan 04, 2011 | Computers & Internet
Hp compaq nx6110 hangin when booting and difficult to recognise the hard drive
Try booting into safe mode by pressing F8 at startup until the boot menu appears. Then select "safe mode with networking". If it boots into safe mode then see if your missing some drivers in device manager. If you are then download and install them. Next run some anti-virus and anti-malware programs to make sure your system is clean.
Jun 01, 2012 | HP Compaq nx6110 PC Laptop
The laptop will only get to approx 80% on the startup bar and freezes. Recognises f2 and f12 but will not go into the bios
check the hard drive and memory with diagnostic boot cd external or boot from disk on key. if everityng it's ok install the os again
Sep 02, 2011 | Dell Inspiron Mini 1012 Netbook...
Hi i just got presario cq56 with suse linux, i want to install win 7 but cannot boot from disc,
You need to change the boot sequence to start with the CD drive on the BIOS.
To access the BIOS you need to tap F10 while the computer is booting.
May 05, 2011 | Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Samsung SD 616E drive not recognized by PC
Check in the BIOS if the interface/port to which you're connecteing has not been disabled. Most bios ' access by pressing del shortly after startup before Windows has started loading. Others access by pressing F1 or F2. (It should indicate what is needed at the bottom of the screen at startup).
Jul 26, 2010 | Samsung SD 616E (729507925578) Internal...
I want to know if i have an internal hhard drive on my acer aspire 7520-5907. I wanted to wipe my hard drive and staart with a clean lap top, but it keeps asking for a password. I have purchased it at a...
Of course your laptop have an internal hard disk drive And it has a working operating system which unfortunately locked by a password.
To start a fresh installation, you need to have a Windows CD/DVD Installer and a valid CD key.
Turn ON your laptop and load the CD Installer. Leave the CD Installer in the CD drive and restart your laptop by turning it OFF and then back on. It will then start the Setup Program which will guide you in installing a fresh copy of Windows.
Jun 10, 2010 | Acer Aspire 3100-1405 Notebook
Error Loading operating system
CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
Dec 31, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
194 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
