Question about Refrigerators
Hotpoint FFA47 no power
I have a Hotpoint FFA47 Fridge Freezer which has suddenly stopped working. I have changed the plug fuse to no avail and proved the plug socket is okay by successfully starting up another appliance connected to it.
I had put this down to a power cut the other day as it appeared to stop working about then?
Anyone got any ideas please?
Many Thanks,
  • Anonymous Jan 02, 2009
    Hotpoint FFA47 no power problem
  • 1,830 Answers
If the evaporator fan is not working the refrigerator will not run.
Posted on Jul 07, 2017
2 Suggested Answers
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
Frige-Freezer not coming on!
there is really nothing You personally can do to fix it, oyu will have to call a serviceman, i reccommend sears. It is a internal circuit or wire that probably blew and needs to really be fixed by a professional.
Sep 14, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
