Question about GE A830 Digital Camera
Camera lens my lens will not come out and stay open
  • Mareliz591 Jun 18, 2008
    when I turn the camera on the lense will not stay out, the screen will not stay on, and the camera will only stay on when in playback mode.
  • hightechgeek Sep 29, 2008
    GE A830 - I push the power button and the green light flashes. Nothing else happens. The lens doesn't open and the screen never comes on. I can spin the dial to any setting - it doesn't matter. The batteries are new.
What kind of batteries are you using? Weak batteries would cause your problem. And have you checked your camera setting? Check the power saving thing, it might be set to turn off the camera.
Posted on Jul 07, 2008
I am having the same problem. Does anyone have any solutions?
Posted on Jun 30, 2008
Why won't my camera lense stay open
Its the power saving feature that retracts lens if camera not used for a set length of time.
If you want camera lens to stay open longer, change the settings by assigning a longer period of time.
Aug 17, 2014 | Cameras
I dropped the camera and now the lens cover does not stay open or closed. It no longer clickes when it is open or closed.
clicking is done when the lens unit/camera i ok,when the camera dropped lens unit must be damaged,so it should be serviced/replace with a new unit
Mar 04, 2010 | Cameras
HELP APERTURE PROBLEM! When I attach any lens to the Nikon FM10
This is normal. the lens stay at the largest opening so you can see to focus, then the mechanics will close to the setting when the exposure is made. This is part of the reflex in single lens reflex (SLR). This part staying open when you focus keeps lyou from having to open the aperture to focus and then close it to the correct setting to shoot the picture.
Jan 29, 2010 | Nikon FM10 35mm SLR Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front cover.you will see a metal cover not properly align.
Apr 06, 2009 | Kodak EasyShare V570 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Dropped camera-lens stays open
The only way to fix a lens error is to send into casio and have it fixed. Call them at 800-706-2534 option 2 and tell them you have a lens error. They will tell u how to go about sending it in for repair.
Nov 25, 2007 | Casio Exilim EX-S600 Digital Camera
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
GE A830 Digital Camera Logo
42 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
