Question about T-Mobile Dash Smartphone
T-mobile dash problems
I want to know whats wrong with my t-mobile dash. Whenever I go to any type of settings an error screen appears stating "Error 'The settings could not be opened'". I can't set my alarm. I can't change my screen options or change it from vibrate mode to normal mode. I can't delete any pictures. I want to know if i could fix the problem or have to get my phone checked out.
Just go the system reset. make sure you save you pictures and stuff to your computer, or it will be erased
Posted on Jul 22, 2008
You need to reload a ROM. Google XDA Forums... 6.1 works well. Follow the instructions.
Posted on Jun 15, 2008
How can i reset the Panasonic KX TG6441 Phone to factory elementry state .
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
HARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
or
Jul 05, 2017 | Panasonic Lands Phones
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
My xbox 360 has one red ring and i dont know if i need a new on or can i fix it
Solution
An error code will appear on the screen as well, which states what component the 360 thinks is faulty.
E67, E68, E79
These could all have something to do with the hard-drive. Try taking the hard-drive out from the 360 and playing without it. If the error message disappears, then your hard-drive is faulty, and you will need to get a replacement. If the error message still appears, then something else is wrong with your 360, and you will need to send in the 360 for repair.
Any other error message is not user-serviceable. You will need to return your console for repair.
Dec 22, 2010 | Microsoft Xbox 360 Console
How can ii unlock a blackberry.?!
How To Enter the Unlock Codes on a BlackBerry Cell Phone
422851199_3d16b31e6c_o.pngModel : All BlackBerry Models (except T-mobile)
1 – Using the menu go to Settings Menu -> SIM card press select.
2 – While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 – You should now see the five locking categories listed.
4 – While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 – Release the shift key.
6 – You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 – Enter the code
8 – Enter Return/Enter
9 – The device should then be unlocked
Model : T-mobile BlackBerry Models
1 – On the Home screen, click the Tools icon. The Options screen appears.
2 – In the tools screen, select the Settings icon.
3 – Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 – Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 – Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 – Input the Network Unlock code
7 – Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 – While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 – Choose “Advanced Options”.
3 – Select “Sim Card”
4 – There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 – Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 – Input the SIM Unlock code
7 – Press in the trackball in once
Your phone is unlocked
Apr 10, 2010 | Cell Phones
I tried to send an attachment to my e-mail address but error 11003 with number 0X800CCC0D appears on the screen. What is the problem of problems?
do you have a yahoo account set up? you may not be able to use it unlesss you pay for it.
http://www.vistaheads.com/forums/microsoft-public-windows-vista-mail/435209-ocket-error-11003-error-number-0x800ccc0d-my-windows-mail.html
Mar 23, 2010 | HP Pavilion A6400f Desktop PC, Refurbished
I HAD NOKIA E90 COMMUNICATOR AND WHENEVER TRY TO UPLOAD SCREEN SAVER & THEMES AN ERROR OCCUR ED CERTIFICATE ERROR:CONTACT APPLICATION SUPPLIER
To get past this error you must (a) change the date of your mobile to a previous date and also (b) in the settings you must set it to Not Check the security certificate.
Oct 27, 2009 | Nokia E90 Smartphone
Yahoo mail loggin error
reset your password in your set file
Nov 11, 2008 | Plumbing
Error
try to reload this software again might be software is currepted or try it in other h set of same brand if possible might be ur browser is not supporting that application.( if possible )  good luck
Oct 06, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
75 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
