LG 52" DLP
My TV appears to be on the fritz and I know its not the bulb. Latelyn when I turn it on I dont get any video, but do get "No Signal" display on the screen. I use component cables and have Comcast DVR box. I swapped cables from component one to two and it was the same. I also tried a different set of cables. After a period of maybe five minutes I'd suddenly have picture, until I turn the TV off again. Is it possible its the cable box?
  • shockwaver13 Jun 18, 2008
    I have the same problem however my component and HDMI work fine, my scart cable wont display!!
2 Suggested Answers
MJS_1
  • 150 Answers
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Posted on Apr 24, 2008
I replaced the lamp in my dlp tv .It turns on for about 5-10 seconds then the lamp turns off and the bulb signal light flashes res
Check to make sure that the lamp housing is fully seated in the compartment, and that the door is properly closed and secured. There's a microswitch on the lamp access door that will shut the lamp off if the door isn't in place properly. That switch itself can be bad and can cause your problem.
Good luck.
Nov 28, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
How to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Jan 24, 2009 | LG RU-52SZ30 52" Rear Projection...
Philips DLP TV purchased
The small signal board is the problem with the set replace that and the set will be fine. the small signal board is the video processor..
Jan 12, 2009 | Televison & Video
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
Open Questions:
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
