Question about Sony Ericsson Z610i Cellular Phone
RSS How do i turn the RSS off? I didnt turn it on. It just seemed to appear!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
1) Go to Messaging>RSS Reader, select it and then press More.
2) Go to the Schedule Update, you will see the option "Every Hour", "Twice a day", "Once a day" and "Never". Select the "Never" option.
After your current RSS finish the update, then the next time it wouldn't turn on again until your manually select "Update Now".
YBC (/\)
Posted on Nov 09, 2009
2 Suggested Answers
SOURCE: RSS
Fo to message settings.
Posted on Mar 31, 2009
2007 Nissan Quest: The RSS (rear sonar system) is not working. The RSS ligt at the RSS button on the dashboard is ON (means RSS OFF). I push the button to turn the system ON (light OFF) and It doesnot...
Hi there:
The number one thing that causes this system to go bad is one of the sensors in the rear bumper is bad and once one sensor is bad the hole system shuts off. Here at the dealer we can hook up a computer to your car and see which sensor is bad, but if you want to do this on your own, you can get one new sensor and install it in one of the holes and see if this repairs it, if not, put the old one back into place and now put the new sensor in the next hole (next sensor).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 21, 2012 | 2007 Nissan Quest 3.5 Minivan
Synchronization error
This happens because you have RSS Feeds, from Microsoft, and they are losing the connection, sometimes, this can be quite normal. If you do not want the to appear any more simply turn off your RSS feeds.
Apr 17, 2010 | Microsoft Windows XP Professional
My boost i776 says rss sim in session how do I fix
If you encounter any problems such as your phone displaying "RSS--SIM IN SESSION" then contact iDEN Customer Support at 800-453-0920.
Feb 08, 2010 | Motorola Mobility i776 Cell Phone
Cannot process RSS FEEDS IN OUTLOOK
Well the link u have provided is not a RSS feed link. I suppose ur searching for some micrpsft feed links. You can find the feed links here http://www.microsoft.com/rss/
Aug 18, 2009 | Microsoft Computers & Internet
RSS Feed isn't working properly in Twitter
First thing is, don't rely on many sites together. Twitterfeed works like a charm and use only that site and forget others. If you have already joined the others, remove the feed from those sites.
Just go to twitterfeed and set the options and feed and have it deliver the feeds every 30 minutes. Remember, twitterfeed will post only those new posts which you made on the blog. It doesn't tweet any older posts of yours which you had before registering with it.
Jun 11, 2009 | Twitter Tweets
RSS
Dec 18, 2008 | Cell Phones
RSS
I would bet that your issue is not caused by a fuse. The fact that the "Rear Sonar OFF" lamp is on and won't turn off means that the system is in fail-safe. The system has sefl-diagnosis capabilities and has found a fault.
To enter the self-diagnosis, turn the key off. Depress and hold the rear sonar switch and while holding it in, turn the key on. You will see the lamp flash and may hear a beep from the warning chime. Release the button and push and release 5 times within 10 seconds. You should see the lamp flash and another beep. Push and release the button one time. This will display fault codes that are stored in the system. For example, if a code 12 is stored, you will see 1 flash, followed by a pause and followed by 2 flashes. If there aren't any other faults stored, this will repeat.
I have seen code 12 most frequently, being that the warning chime has failed. If this is the case with your vehicle, you won't hear the beeps that I mentioned earlier, but only see the flashing of the lamp.
If this is the case, you will need to replace the chime. It is located under the cover between the steering wheel and the windshield. There is a "hood" that faces toward the steering wheel and behind that is a cover that is held down with spring-metal clips. Get a small screwdriver or panel "popper" under this cover and gently pry it up. The chime is a small speaker directly under that cover and is bolted down with 2- 5.5 mm bolts.
Once you have repaired the fault, the system will automatically reset the self-diagnosis memory.
If you have other codes, you may have an issue with one or more of the sensors located in the rear bumper. I, however, do not know those code numbers off the top of my head.
I hope that you have found this helpful!
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Oct 27, 2008 | 2005 Nissan Quest
RSS
YBC (/\)
May 04, 2008 | Sony Ericsson Z610i Cellular Phone
Deactivate rss feeds
Remove it instead of adding it.
How to add RSS channel to the RSS reader (K610/K790/K800/W830/W850/Z550 series)
In order to add an RSS channel to the RSS reader do as follows: 1. Go to [MESSAGING], press "Select"
2. Scroll to [RSS READER], press "Select"
3. PRESS [ADD]
4. Enter the RSS address
5. Press [GO TO]
6. The phone will automaticaly connect with the selected page, and the RSS address will be added.
Jan 27, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Z610i Cellular Phone Logo
226 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
