Question about Nokia 5300 Grey Cellular Phone
Headphone Socket Part of my headphone adaptor has broken off inside the phone. Anyone know if its possible to open the phone up to get it out before I try & force it open & inevitably break it? Cheers...
  • bournio Jun 12, 2008
    Same thing with me, I've not done anything to resolve it as i dont want to break i anything!
  • Anonymous Mar 02, 2009
    after removing my broken part of headphones inside the socket, i only hear 1 side of the earphone, the right side doesn create any sound. wht can i do? can i buy a new socket?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Get it to the techinician.
Posted on Jun 13, 2008
You could always just put a little bit of super glue on the end of a paper clip and carefully poke the broken piece until it sticks, then pull it out. Tah-Dah!!!
Posted on Jun 14, 2008
Why do I get no sound from either speakers or headphone jack?
Check that the local control is ON
It is set via the function switch
Dec 09, 2015 | Yamaha DGX 530 Keyboard, 88 Full Sized...
I have use nokia 2310 model but one of the problem is headphone socket he is not connect to headphone switch so pls sir give me information my E-mail id shreeramkharat@gmail.com
Check the headphone on another phone to confirm if this is working correctly. If not you need to check the pins or the wires for fault or replace the headphone.
Since your question is not clear , it is hard to understand what you meant. Also if the phone does not work with a confirmed working headphone then it is possible that the socket is faulty.
Jun 28, 2011 | Nokia 2310 Cellular Phone
Head phone socket intermitent and now failed. Any idea what to solder where?
the headphone jack would either be a 3 prong or a 4 prong. meaning it was either had 2 contacts on the headphone barrel or 3 contacts and the last prong being for ground. If you desolder the headphone jack you can easily determine this. Then you can goto a radio shack and pick one up for under 5 dollars. Problems that may come into play are is if they used a low profile jack over a standardized. But even if its 3.5mm or 2.5mm radio shack generally always sells them. You could also purchase them online. Most likely the cause is the contacts inside the headphone jack are no longer making contact with the barrel of the headphone plug. But if its not the headphone jack then it is possible the amp inside the unit has broken. also if you open the unit up determine if the solder on the headphone jack that makes the contact may have become cracked. If that is the case just heat up a soldering iron and make circles around the solder, but be careful not to spread the solder and cross connections.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Samsung YP-K3 MP3 Player
No audio thru the speakers, headphones only
you answered your question. let me explain: the head phone plug is a switch- that disconnects the speaker and only allows sound to the headset. the switch is either broken, loose-wire or dislodged.need to get inside the unit, You could of course get creative. put an adaptor to the headphone jack;the adaptor can now allow you to run wires to the speakers. adaptor is avail from radioshack-same size as on the headset.
Mar 04, 2010 | Philips MCM530 CD Shelf System
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
Record from tape deck to computer via USB and Audacity software
Im not sure what DIN sockets you're trying to describe here, but quite often, you can record from a tape player to a pc by connecting an rca cable to an adaptor; rca to 1/8"(headphone pin) and then plugging that headphone pin in to the microphone input on your computer.
Jun 22, 2009 | Audio Players & Recorders
Socket for headphone broken on my Sony Ericsson W760i
it might be your headphone that is broken and yes it probably can. just bring it down to your networks local store and they will try to solve the problem straight away!
Jan 13, 2009 | Sony Ericsson W760i Cellular Phone
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Aug 12, 2008 | Fujitsu AMILO Pro V1000 Notebook
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Nokia 5300 Grey Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
