Question about Acer Aspire 5600 Series 5630-6951 Laptop
Laptop was working fine, but doesn't turn on anymore...
The laptop was plugged in with the battery attached as well, then suddenly it turned off. It would not turn on after.
The AC adapter still works, but I think the battery is shot because I put it in another Aspire 5600 and it doesn't show the charge rate of the battery.
I did not smell any burning in and around the laptop, and I tried doing the "Discharge Method" which I read about here.
Any solution would be welcome...
  • 458 Answers
Laptop was working fine, but doesn't turn on anymo - a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Posted on Jun 04, 2008
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
My acer laptop suddenly shutdown then it didn't turn on,the led of the charger is blinking,what is the problem?
you may have had a surge on your charger, i'd unplug it and try a different outlet. After you unplug it, remove the battery for about a minute, then when at the new location plug the battery back in and then the charger. see if that works. if it doesn't it's possible that your charger just died. Did you happen to look and see how much battery you had available when it died?
May 14, 2012 | Computers & Internet
Laptop wont turn on, lights flashing, fans running
Sounds like your power circuit on the motherbard is cooked...really cheapr to buy a new one than to have that one repaired.
Mar 31, 2010 | Toshiba Satellite A305D-S6835 Notebook
Unknown problem
I would say your battery is fine. What happened is the computer was running off the battery even though it recognized it was plugged in. There is a piece in the power jack that tells the laptop that you are plugged in, but it doesn't necessarily mean the adapter is working. I would have the adapter checked to be sure it's working before I suspected the battery.
Jan 08, 2010 | HP Televison & Video
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
T20 wont turn on
make sure the battery is unplugged from the laptop and only hook up the ac adapter. If you can't get it to turn on then try anotherr knowng good working adapter and if it still can't turn on then the motherboard is bad and will need to be replaced.
Jul 06, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with distrubing power to my HP dv6700 laptop!
You may have more than a dead battery problem, but possibly a problem with the ac adapter or the internal psu. Does this only happen with you try to use the laptop with the battery removed? or does it fail to turn on with or without the battery snapped in?
Jun 09, 2009 | HP Pavilion dv6000z Notebook
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer Aspire 5600 Series 5630-6951 Laptop Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
