Question about Honeywell Heating & Cooling
I have an Ideal Classic FF240 gas boiler. I noticed that there was no hot water or heating. On looking at the boiler I noticed that the pilot light ignites but the burner does not fire up. Is this something that can be easily remedied?
The solenoid is not opening the gas valve so you need to replace the gas valve, as for price I have no Idea...
But please remember to get a GAS SAFE REGISTERED engineer to carry out this simple replacement...
Posted on Jan 20, 2010
A gun to the head
Posted on Jun 04, 2008
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Gas boilers
The contacts in the heat relay may be stuck closed
Feb 08, 2014 | Honeywell Heating & Cooling
I've just moved and the boiler is an Ideal Classic
it should be a fully pumped system , which pumps heating and the hot water i take you have ahot water tank /cylinder for hot water with a 3 way valve on it , hmm set the boiler thermstat to number 5 put you clock /programer to hotwater only,once aday or twice , its down to how much water you need . see if this helps .
Aug 24, 2011 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Broken heat exchange in boiler leaking hot water onto pilot light
Maang, You are a year older than me, so lets see if I can point you in the right direction.(1) If you have access to the internet you should be able to find a manual for an "Ideal Classic Boiler".(I just did) but you'll need to print it out - 40 pages. (2) It is 12 years old and is past it's half life. You might consider a whole replacement boiler - installed by a professional contractor rather than replacing a cracked section of the heat exchanger. Any equipment is only as good as the installation and proper setup when it is new. (3) You should NOT be smelling any gas in the house, period - unless you have a leak. You may be smelling carbon dioxide which is from burning fossil fuels - escaping from the crack in the heat exchanger. (4) What happened to the "Warranty" ?. Before you blow yourself up, Don't try to light the pilot anymore. Call a legitimate contractor.
Mar 29, 2017 | Heating & Cooling
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Heating & Cooling Logo
702 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
