Question about Lexmark X5470 All-In-One InkJet Printer
Cannot get my x5470 to 'communicate' with my compaq laptop.
I am using a belkin pro series usb 2.0 cable to connect the x5470 to the compaq c350ea-is this lead ok 'coz the x5470 is a fax machine aswell
many thanks
  • 550 Answers
Yes,
but the printer can only be used as a fax machine if the phone line jack on the printer is also connected to the phone line jack on the wall.
Posted on Jun 20, 2008
We've tried the belkin play wireless usb adapter in 2 laptops with xp pro and it wont connect the signals great it says the card is working properly but it just says it cant connect i've had this same...
Have you got two wireless icons down on the right by the clock. As it may be using the belkin wireless manager to control the device rather than the windows version.
Mar 11, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I'm trying to install the Belkin router and I get an error
If the cable is too long from the MAIN phone socket you won't get the signal to your router.You set the router as close as poss to the MAIN phone socket i.e. 2 to 5meters away.Then use a wireless adapter connected in your desktop USB socket.Use the adapter disc to set it up.This receives the signal from your router and installs it into the USB port.
Dec 05, 2009 | Belkin (F5D5231-4) Router
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Connect Lexmark X5470 via wireless router
I would like to inform you that Lexmark X5470 is not a wireless printer. However, if you want it to use wireless then you should have a Lexmark N4050e 802.11g Wireless Print Server.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
Apr 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Belkin wireless keyboard receiver won't work with my laptop
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
Dec 18, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error Printing to LPTUSB1 for the printer Brother Hl-1230 series
Connect the device to a different usb port. Download the newest software/drivers from the Belkin web site. Remove the old software and install the newest downloaded version. Please supply the error.
Apr 09, 2007 | Belkin USB Parallel Printer Adapter...
Lexmark X5470 All-In-One InkJet Printer Logo
131 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
