Question about Toshiba Satellite A105 Notebook
Black screen I changed some settings and now after a few seconds my screen goes black....when i start up i see that windows is loading and then screen goes black and i cant see my icons/desktop on my Toshiba laptop....I changed it from standby to hybernation when i close the top down or its idle for 15 it seem to go into hybernation in just a few seconds....the only way i can see my desktop is to close and reopen my top and i can only see my icons for a few...3-5 seconds...then my screen goes black....can it b stuck in hybrnation??.....i tried turning it off n on several times, i took battery out and put it back in, i even hit the F keys on startups but that just made it come up in safe mode for a few seconds then go black again....i bought my Toshiba satalite august of 06.....Please help Thanks, Karmel
  • 458 Answers
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Posted on Jun 04, 2008
  • Garry Romaneo
    Garry Romaneo Jun 04, 2008
    if Not a Lid Pin issue then try to boot in safe mode to reset your Power options
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems. -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Black screen?
can you plug an external monitor and see what happens?
also while windows is loading press Fn key and f8
Mar 25, 2009 | Dell Inspiron 1525 Notebook
Start up problems with Sony Vaio VGN-A517S
remove your screen saver program form computer.go to control panel in settigns u se dispaly open it then set desktop as win xp.
Feb 03, 2009 | Sony VAIO PCV-J200 PC Desktop
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Toshiba Satellite A105 Notebook Logo
444 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
