Question about Kenmore 24032\24036 Top Load Washer
Washer does not drain when in the spin cycle
I have a modal that looks similiar to the kenmore24032 and it will go in the spin cycle but it does not drain all the water. So , I have to stand down there and keep putting it on the spin cycle.
    Genius:
  • 1,028 Answers
Lean washer back remove the 2 clips holdong pump to motor remove the 2 clamps on hoses remove pump and ckd for blockage
Posted on Jun 06, 2008
MAH3000AWW washer goes thru spin cycle but leaves the clothes really wet and is really noisy.
had similiar problem , there was a piece of clothing stuck in a drain hose
Mar 02, 2013 | Maytag Neptune Washer
RE. Bosch Nexxt 100 series. Does not spin. I have cleaned all hoses, outflow and inflow. Opened the little circle door at bottom right and it is clear. The fan even spins during drain cycle. I do hear...
Check connectors on motor assembly they can become loose due to the high speed and vibration. Motor and drum are tied together. I had similiar problem with mine after spending a few hundred on a control board which made no difference.
Oct 12, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer kenmore24032 ser 1001761 m111
sounds like the transmission. take the moter and pump off and manually turn the transmission and see if the tub turns
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
Hotpoint WMA76 Ultima 6kg
either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
djkb
Jun 26, 2008 | Hotpoint WMA76 Front Load Washer
Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
http://www.frigidaire.com/products/laundry/washers/front_load/prod_ATF7000FS.asp
I hope some of this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
