Question about Intel Motherboard
Motherboard and BIOS problems
Hello! After installing Windows XP2 the system doesn't load Windows and friesens, but if I install Windows XP1 everything works right. The Motherboard is ARISTO KT133, BIOS-2M (2K010223B), 02/23/2001-8363-686-6A6LMPR9C-00. May be I need to reflash my BIOS? Then where can I find needed files for my bios? Thanks!
  • steveveg Sep 09, 2008
    HI I have just instaled my secondhand P4S800-MX motherboard, the problem i am having is when i try to install windows xp service pack 2 my pc freezes on a black screen. I then have to run system restore to go back to another date before the service pack 2 was installed to get my pc up and running again. Please help.
Hello
good morng
th m.b is pasword lock
Posted on Jun 04, 2008
  • ali alwafi Jun 04, 2008
    pasword paios
My PC : 945GCM2S-A2-6H Mother Board 1.60 Intel Pentium (R) Dual CPU E2140 @ 1.60GHz 1.60GHz 1GB RAM 80GB HDD ATA Formatted , Partitioned. IS OK. OS: Win xp2 is OK. PROBLEM: Every time when the PC...
might be cmos battery is flat on the motherboard and it is forgetting the Type of hard drive you have.
Suggest looking for cmos battery it might be a cr2032 type battery attached to the motherboard .
Mar 26, 2017 | Microsoft Windows XP Professional
Xp installation problem hp compaq dx6100mt
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Jun 08, 2012 | HP Computers & Internet
Hi , my motherboard is k7n2 delta 2 platinum ms-6570e , i've had a problem to install windows xp , but finally i did it . Now i've got problem to install some programs like office , nero itp....
Hi, you can download the drivers manualy from here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Driver&os=XP%2032
The drivers or the bios file needs to be unziped before installation.
Install first the system and chipset drivers.
Try also to run windows update.
You will need the updates to install office and etc.
Try also to add more memory ( ram ) to your system.
Supports DDR200/266/333/400
Aug 24, 2011 | MSI K7N2 Delta2 Platinum Motherboard
I just bought a new lap with ST9250315 AS HDD and i can't install winXP on it. First setup crashed, but i changed the BIOS setup for IDE instead of AHCI. After that installation goes ok until i...
Sometimes, recent hardwares (laptop components) don't have its drivers for XP1 & 2. (It conflicts.)
Try with XP3. Otherwise, you have to reinstall win7 and run win XP virtually under win7.
May 26, 2011 | Seagate Momentus 5400.6 (ST9250315AS) 250...
I had 2 x 512mb memory installed with no problems. I recently installed 2 x 1Gb but the bios does not recognise it. The pc always hangs on boot up just before loading windows. The pc will work with the 2 x...
Hello gphillips397!
Abit has released an updated BIOS for the IC7-MAX3 motherboard which fixes quite a few issues with your motherboard including one that can cause the system to hang with certain memory modules. The updated BIOS is HERE and instructions for the upgrade are in Appendix G of the User Manual or a general guide is HERE
Nov 22, 2010 | Abit IC7-MAX3 Motherboard
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
I will install windows xp2 and i have program windows xp1 but driver can't progress and i have lost of my hdd cd but my pc want it. could you give me solution
the fastest way is formatting, not upgrade. If you want to save your important file first, use live cd like avast bart pe or something like that to copy or transfer your file to another partition.. This if you can't access your hard drive
May 07, 2009 | Computers & Internet
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
Motherboard upgrade??
Dear kaname,
Your computer can support Windows XP, which has better hardware support and compatibility with the 2003 Office suit. XP also updates your hardware automatically once you are on the internet. You might want to try this.
Keep in mind that the older the Operating System, the harder it is for Office suites to compat. Newer Operating systems have better support for your computing. If you don't have HDD problems, the BIOS should not prevent you from loading SP2 for Win2000.
Conclusion:
1. The SP2 Source Disk may have a problem
2. The Win 2000 you have already loaded may be missing components, preventing the SP2 to load.
2. Notton Antivirus versions and the 2003 office both reject Win 2000. They just don't like it; it's getting too old.
Get with it, Kaname!!!!
Feb 27, 2008 | A-Trend ATC 5220 (ATC-5220) Motherboard
Intel Motherboard Logo
391 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
