Question about Canon MX300 Office All-In-One Printer
Error U163 When I turn on the printer, the alarm flashes and it displays the message: " Check ink U 163" I have replaced the black cartrige with a new one, but I can't overcome the problem. What should I do?
  • 1 more comment
  • Anonymous Jun 05, 2008
    Cuando se me acaba la alguna tinta, no me permite utilizar el escaner
  • Anonymous Dec 17, 2008
    meme chose pour moi
  • Anonymous Jan 09, 2009
    Same problem???
  • 5 Answers
Press and hold the 'Reset' button down for 5 + seconds.
Posted on Oct 14, 2008
  • 3 Answers
Just press the stop button for 5 seconds or more
Posted on Feb 26, 2010
    Guru:
  • 1,342 Answers
Try running the print head cleaner.
Canon Support Site
Posted on Jun 04, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Ive replaced black ink cart but it doesnt work,still the message check ink u163 on th LCD.thank you
Either the new ink is a generic cartridge and not reset properly, or one of the other inks is empty. Your display should tell you which ink is empty. U163 just says that one of the inks is empty.
Feb 05, 2010 | Canon PIXMA MX300 All-in-One Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
I have replaced both the color and black ink cartriges, however the printer is giving me the "color ink low" indication and a check ink u163 blk alarm. We have reset the cartriges to no avail.
Per the Canon.com troubleshooting guide found on THIS WEBSITE, it would be recommended to ensure that you have the proper cartridge for your printer. Also, double check that you have fully seated in the cartridges and that they align as they should. Lastly, it is important that you are using Genuine Canon ink cartridges to ensure longer printer life, not void any warranty you may have remaining on the printer, and most importantly to ensure proper communication with the actual cartridges.
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
U163 problem
More the likley, your printer's manufacturer does not allow for the use of refilled ink cartridges on their products.
Please purchase a factory new cartridge from the manufactuer of the printer.
Aug 14, 2009 | Office Equipment & Supplies
CANNON PRINTER/CHECK ING U 163
u 163 shows in disply-not working the printer
Apr 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When I turn on the printer, the alarm flashes and it displays the message: " Check ink U 163" I have replaced the black cartrige with a new one, but I can't overcome the problem. What...
may be there is a problem with the colour cartridge,or also it is possible that the printer circuit surface that touches the cartridge circuit is not cleaned.clen it with a damp cloth n reinstall cartridges.wish u luck
Jun 04, 2008 | Office Equipment & Supplies
Canon MX300 Office All-In-One Printer Logo
7,097 people viewed this question
old marine
old marine
