Question about LaCie Ethernet Disk (300626) 500 GB Network Storage Server
Lacie 300626 500gb
Does anyone know if this does raid?
thanks
mark
Yes it is raid
Posted on Oct 14, 2008
LaCie DD3US: Can I upgrade the 2x500gb for 2X4tb in raid 1 for iMac.
No. I don't think the power supply is strong enough to handle a 4TB HDD - let alone 2
Check the manual for maximum supported drives.
Apr 14, 2016 | Computers & Internet
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
Lacie raid drive failure
You have a failed RAID array. These guys do raid recovery remotely over the net... http://FreeDataRecovery.us
Sep 09, 2012 | LaCie 2Big Quadra 6TB 2Disc RAID External...
Server error 500
The adress of the server error is 00:D0:4B:8D:1C:50. Has anyone a solution? and The message was " Something wrong with the volume CNID BD"
Feb 29, 2012 | LaCie 2big Network (2-disk RAID) (301257U)...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
Backup slow
You don't specify whether previously on your USB it was the same lacie external or whether it was a different external drive. It sounds like you were using a different external drive, most likely a single drive.
You've specified that you've got your lacie setup in raid 5. Raid 5 gives a very good read spead and a good redundancy for incase a drive fails, however it's write speed is very very slow.
It will be much slower than a single drive on USB for writing to it (i.e. backups), but you should see a huge performance boost in reading from the drive than your previous usb.
If you need it to be faster, you would be better suited looking at configuring it for one of the following raid setups:
Raid 0: striping (not recommended for backups) - data is split over all drives, however if 1 drive fails you lose all data.
Raid 10: striping + mirror . half the drives are striped (like above), but the other half mirror the striping half so if one drive fails there's a backup of it. You only get half the disk space though, so if you have 4 x 1Tb drives, then you'll only get 2Tb of space.
Apr 06, 2010 | LaCie 2500 GB Network Storage Server
WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Disk manager only sees 25% of it
your partition size is incorrect not disk manager
Apr 27, 2009 | Computers & Internet
Replacing Drives
You can use any brand or any size. It does not have to be a Lacie Brand Drive, but if you planning on using the RAID which makes an exact copy of one drive on the other drive in the server, you must pick two identical drives of the same brand and the same size. It can be any brand or size but both of the drives have to be identical. Otherwise, the RAID Will not work.
If you have any further questions, please let me know.
Jan 09, 2009 | LaCie (301258U) 750 GB Network Storage...
LaCie Ethernet Disk (300626) 500 GB Network Storage Server Logo
145 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
