Question about Zanussi ZWF1430W Front Load Washer
My washer wont choose a programme
My washer has the three lines and will pick a programe but when i press start/pause button it changes programme each time i press. but the other buttons wont work????
    Problem Solver:
  • 4 Answers
Push start buttons more than 10 second
Posted on Jun 04, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
CHANGING A STORED NUMBER
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
Sep 15, 2009 | Lands Phones
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Zanussi ZWF1430W Front Load Washer Logo
130 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
