Hotpoint First edition 800 WM51
Could any of you guys help with this big problem I'm having with our Hotpoint, I fiited a new timer (controller) and Motor to the machine yesterday. by the way the machine was working before hand but the motor was noisey and machine washed when it felt like it. after changing these parts the machine seemed dead. so I went back to the shop and he gave me another timer to try. fitted that and it still seemed dead, phoned the washing machine repair shop and he said to by pass the door lock as that could be the problem. I joined the two wires red/green and the brown/green together and presto the machine sprang to life. every thing worked fine except no door lock. I went back to the shop got a new door lock and fitted that. Machine dead!. I phoned the shop back up and he said maybe I had the wiring wrong on the door lock and try switching them round. I tried that. machine came on for about 5 seconds a small amount of smoke came from the timer ,then it tripped the fuse board out. I bypassed the switch again and the machine worked, but when I turned it off at the button on the machine it trips out the fuse board. even when I put all my old parts back in its still not working. it just trips the electric. I may have mixed the up the two connectors to the timer , ones purple and the others green not to sure if green is fitted at the top or bottom of the timer. also could you tell me which colour is the live to the door switch, brown/green or red/green.
Many thanks
Ian
This is a UK machine as I'm in the UK
  • 209 Answers
SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Posted on Oct 03, 2007
  • 183 Answers
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
  • 135 Answers
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Posted on Jan 23, 2009
dmftrucker
  • 1922 Answers
SOURCE: why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Posted on Oct 28, 2009
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
Hotpoint FUFL 1810 G Heater element always on, What can be a problem guys? Any idea? Anyone met with this problem before?
It is impossible to say, since you did not specify the MAKE or MODEL of your refrigerator.
If it is an older refrigerator, it is possible that your defrost timer has become stuck in "defrost" mode.
May 11, 2015 | Refrigerators
Hotpoint wm51
get a new lock they are cheap
Apr 15, 2014 | Hotpoint First Edition FEW12 Front Load...
The main wash is cold and the rinse is hot. hotpoint wm51
You have the hoses hooked up incorrectly or the water inlet valve is faulty.
Jan 13, 2011 | Hotpoint Washing Machines
HOTPOINT FIRST EDITION 800 WM51 USER MANUAL?
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
Washer wont start hotpoint first edition 800, WM51
If you have established that the washer is getting power, then I would suspect that the door interlock is the cause of the trouble., try fitting a new one.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Dru wont turn at all
Hi, welcome to Fixya.
The belt has come off for a reason, and there are a few reasons for it to do so.
1- You have overloaded the m/c
2- It is not draining properly.
3- The main drum bearings have gone. Before replacing the belt spin the drum by hand, and if it is noisy or feels rough , then the bearings have gone.
That means calling an engineer.
4- Worn or broken belt.
To refit the belt, do the following.
Remove top cover, and rear panel.
Tilt the m/c forwards, and support it.
Reach inside and slip the belt over the motor pulley, then start feeding the belt round the drum pulley, it is fiddley, but this is the only way, as you get the belt futher round, it will get very tight, so don't trap your fingers, just keep on going.
If it slips off, start again.
Goodluck.
Plz rate my solution.
Thanks, And a merry xmas.
Dec 22, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Mistral fridge freezer frost free Model 8596P
Hi Avaline,
You need a new friend!
If the unit is 10 years old or more it does not pay to fixit! the new ones will save you big time energy!
OR,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 21, 2008 | Freezers
Hotpoint first edition
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Mar 16, 2008 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
456 people viewed this question
Top Washing Machines Experts
