Question about Maytag Atlantis MAV6000 Top Load Washer
COLD WATER WE CANT GET COLD WATER. WE CAN ONLY WASH IN WARM AND HOT.
  • MrsPatty62 Sep 15, 2008
    My cold water runs extremely slow but the hot water runs really fast.I purchased this washer 6months used with no manual. Where is the screen on the cold water hose so I can clean it to get water flow corrected?
  • 246 Answers
3 suggestions. 1st, make sure all of your valves are open. (some times installers forget to open them back up after the install) 2nd, fill the machine until the water gets hot. Check on the rear of the machine and make sure the hose going to the "COLD" valve is not hot (somtimes these hoses are reversed when they are installed) if those are both ok, then 3rd shut the water off and unscrew the cold side hose. (There is a screen underneath that can get covered with sediment from the house water supply and cause the water not to flow)
Posted on Jun 15, 2008
My F&P WA75T65GW1 will not fill to rinse after the wash water has been pumped out. If I manually fill it, it will continue the cycle. Are you able to help? Thank you
when you wash do you set the water temp to warm or hot? it may have a broken cold water valve and may be filling with just hot water when washing instead of both, so when it gets to the rinse it cant fill with cold water, if you set it to just cold water does it fill on the wash?
Jan 31, 2017 | Washing Machines
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine cycle far too long
Hi Fiona.I believe the cold valve is probably faulty & is not flowing fast Its probably dribbling water in?taking forever to fill.the machine should be giving up & beeping at you if thats the case.If you have a faulty cold valve then switching to warm won't help as the hot valve will close itself off to compensate for the lack of cold water..afterall you have told the machine to fill with warm,,if it cant make warm water because of a faulty cold valve then the hot will decrease to a point where its not letting any water thru..try a hot only wash..if it goes thru wash cycle ok then good chance its cold valve problem.wow i hope that helped.
May 30, 2010 | Fisher and Paykel Washing Machines
Unit will not complete wash cycle that uses hot or warm water
do you have cold? will stop at rinse cycle and hum if you have no cold
Jan 09, 2010 | Washing Machines
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
