Question about JVC AV-32260 32" TV
Black box appears in TV screen
Last night suddenly I experinced some screen problem in my TV. A big black box appeared and remained on the screen. The sound is fine and if I change the channel the box will disappear for a second and then come back up. One interesting thing, when I change the channels, I can view 3-4 local channels without black box I tried unplugging it and connected again with no change. When I try to watch VCR run, black box is still there but when I try to watch DVD player connected with TV, the black box is not there.
Anyone have any suggestions?
  • 2 more comments
  • Anonymous Jun 20, 2008
    was THE TXT THING!!! totaly work thanks
  • shireenaoh Jul 24, 2008
    Whenever I was TV/VHS/DVD on my JVC a black box appears and goes away and appears again, consistently. What do I do to make this go away?
  • drzook12000 Aug 04, 2008
    bkack box in middle of picture. tried to fix by using menu. dosn't work. udn
    pldruged TV and Directv box doesn't work Suggestions please
  • Anonymous Jan 16, 2009
    i have zenith tv combo 19 inch, and black box is in the screen how do i get it out with the tv remote
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
Nah its probably your TV setting its a simple closed caption setting ...set it to off and you should be good to go ..my tv was doing the same thing
Posted on Oct 09, 2008
    Genius:
  • JVC Master
  • 1,550 Answers
Go to the Tv menu and check the text function maybe you activated by mistake turned off.
Posted on Jun 05, 2008
  • Debjohn69 Apr 12, 2012
    Great right on!
I have a Toshiba model MW24FM1 TV (2002). Had big solid black boxes on just a few channels. Took off closed captioning and boxes went away.
Posted on Jan 28, 2013
I've been having the same problem. My neighbor was just here and said he'd had the same problem with the TV at work. The parental controls were somehow activated accidentally and could not be unlocked with the universal remote. He said he had to rummage around the basement until he found the right remote for that TV, but was able to fix the problem with it. I have just ordered a new remote online from JVC. I don't know yet if it'll work, but it's worth the $23 if it fixes the TV. Here's the link: http://www.jvcservice.com/service/default.asp
Let's hope it works, if you like, I'll let you know how it goes for me. Good luck!
Posted on Jun 20, 2008
When changing channels----Big black square appears on screen
turn off the closed captions or select c1 to view the captions. Right now they are set for text and that is what is causing the black box to appear
Jan 09, 2009 | Sansui DTV2760 27" TV
Big black box across the screen towards the bottom.
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Dec 13, 2008 | Toshiba CF36G40 36" TV
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
Zenith TV has a big black box in the middle of the screen.
After reading other postings, we figured out that it was the caption box, went to menu and turned it off.
Thanks for the great site, we wouldn't have figured it out without it !
Jen
Nov 15, 2008 | JVC AV-20220 TV
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
Ctv 41301.... can't remove black box on the screen
A square box imposed on top of pix is called a text box.
It is controlled thru the Closed- Caption menu selection.
Enter CC menu and make different selections-try them all,it will help you to understand.....,..T.
Oct 05, 2007 | Craig CTV-41331 13" TV
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
JVC AV-32260 32" TV Logo
2,528 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
